Results 1 to 15 of 15
    Reputation: Lombard's Avatar
    May 2014
    650b Wheel Build for Gravel Bike
    Hi all,
    I am considering building up a 650b wheel set for my gravel bike that now has 700c wheels. I will like to run 650b x 47mm tires.
    The bike has 12x100 TA front and 12x142 TA rear, so I will be using Shimano RS770 centerlock hubs.
    My question is on rims. What are some good choices of 650b rims? Right now, I'm leaning toward the DR Swiss XM 421. I am thinking 25mm internal width would be a good choice for 47mm tires?
    Any thoughts or opinions?
    Thanks in advance!
    -- Warren Buffett
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Many to pick from, sampling:
    Rims - Wheel Products - 650b
    May 2014
    Thanks Marc. I have seen this site. I was looking for anybody here who had experience as to what is good and what to avoid because of problems.
    -- Warren Buffett
    Aug 2012
    I suppose much of it would come down to your weight.
    I'm 61kg and use the XR 331, which is 20mm Inner.
    Does fine for me using Compass 48s to Schwalbe 2.1s.
    May 2014
    Quote Originally Posted by tangerineowl View Post
    I'm around 180lbs. (80kg), so I would want something a little more robust.
    -- Warren Buffett
    Jul 2014
    I'm in the middle of building a set of 650b wheels. I chose Kinlin TL23 rims because I was pretty price sensitive for this build and I have read a number of good opinions of them in various places. I'm building them 32/3x with Sapim race spokes and Bitex BX106 centerlock hubs. With nipples and nipple washers and bikehubstore's black Friday discount the set comes in at around $300.
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    Since I'm using a big tire (42m) at low pressure and disc brakes I went with carbon. They are so much lighter and I've really tried to abuse them. They have been really strong (a few D2R2 rides and the like). Using Nox Skyline rims which aren't too crazy expensive. They also have a heavier model.
    Others have reported good results with rims from Light-Bicycle which cost less. I think carbon makes sense in this application.
    For alloy also DT is great and also look into the new rims from Astral (Rolf). They are made here and Rolf quality has been good.
    https://astralcycling.com/
    Sep 2015
    DT Swiss XM 421 is a great rim choice.
    I would recommend the Bitex BX106 centerlock hubs instead of Shimano.
    Lighter and easier to maintain.
    May 2007
    Regardless of what rim you choose, i think the first thing is to determine your own attitude about rims. For me, i think i'll assume rim strikes are going to be rare, so if i smash one it's because of a significant and uncommon mistake and that no rim was going to survive. Those happen sometimes when you ride dirt, so i don't want it to be super expensive. I'd choose a lightweight alloy rim.
    If i felt differently about the frequency/severity/expense of rim strikes i'd reevaluate my rim choices.
    I'm a big fan of WTBs line of rims because they're using a harder aluminum and a UST bead seat. For your application i'd buy a KOM. There are other options that are probably as good/better, but having run a lot of rims that's my inclination. There's definitely more worse options than better.
    May 2014
    Quote Originally Posted by bubble View Post
    Right now, I have WTB i23 STS rims. I have no problems with those, but from what I have read, some of WTB's rims aren't the easiest to build with. I don't know why that would be unless there are inconsistencies of roundness coming out of the factory.
    -- Warren Buffett
    THe KOM's I've used were fine, The offset Assym rims have been inconsistent. I had a hard time keeping equally tension and roundness. Seams were horrible.
    FWIW, I'm using a Stans Arch MK in 700c with a 45c tire. In 650 it would be a little stiffer. I usually run about 32lbs on gravel, and no more than 45 on road. Its about as wide of a rim as I would use for gravel type tires.
    May 2007
    I have no idea; i've found the st/kom/frequency/asym to all be easy to work with. If anything the koms are the trickiest.
    It's excessively lightweight or cheaply produced rims that give me trouble, and i avoid those anyway because that's now how you get good wheels.
    May 2014
    Thanks everyone! I hadn't thought of the Stan's Arch MK3s, but those are now on my short list. Is this rim welded or sleeved?
    -- Warren Buffett
    Sep 2015
    Arch mk3 is welded. It's an excellent rim.
    May 2014
    Quote Originally Posted by MudSnow View Post
    Thanks Mud! It's now between this one and the DT Swiss XM 421.
    -- Warren Buffett
  1. Gravel Bike Wheel Build
    By Lombard in forum Wheels and Tires
    Last Post: 10-28-2017, 02:33 PM
  2. Gravel Bike wheel q: Stan's ArchEX on gravel bike
    By stuarttx in forum Wheels and Tires
    Last Post: 03-23-2017, 06:53 PM
  3. Replies: 0
    Last Post: 11-17-2015, 07:00 AM
  4. Spring Gravel in Acadia with Ti Merckx 650B
    By singlecross in forum Commuting, Touring and Ride Reports
    Last Post: 04-18-2012, 02:15 PM
  5. Recommendations for a 650B or 26" wheel 'Country Bike'?
    By SystemShock in forum Bikes, Frames and Forks
    Last Post: 07-08-2008, 11:09 AM
