There's a lot of back-and-forth, and they are close enough that some of the answers overlap depending on brands and models. But generally, 23's are lighter, 25's more comfortable. You'll have some arguing both sides of the efficiency question, but at the end there's so much overlap there that models and pressures chosen matter more.
IMO, unless you are racing, there's little reason not to ride 25's. If you are racing, there are arguments to be made for either.
Weight does matter, though at yours, not as much as someone heavier. 25's would let you run 95 psi or so safely, getting comfort from even fairly stiff, 'durable' tires.
25's at 90psi are like a breath of fresh air after a few decades of 23's at 100-110psi. If I was racing I just might consider 23's. But I'm not anymore.
Let's not talk about the handmade 32mm cyclocross tires at 40psi that I used for the whole summer on dirt roads. Sheer luxury.
Related Threads
Road Bike, Cycling Forums
5.4M posts
205.1K members
Since 1990
