Results 1 to 16 of 16
    Oct 2008
    700x28 tire for mixed riding
    I am going to put some 700x28 tires on my corss bike for training purposes for the summer. Primary use will be rides with less than about 30% dirt roads. This doesn't mean roads with deep gravel but more dirt with some gravel. If I do a mainly gravel ride I will throw some 33 or 35 cross tires on.
    Current Considerations are:
    Schwalbe Durano or Clement strada 120TPI
    Haven't found a lot of info on either in a 700x28 tire.
    Any experience with either of these folks can share?
    Any other options I am missing?
    I live in Mid-Atlantic central VA area so really mixed weather and this will be the rain bike when the mtn bike trails are too wet! Also will use in some Roubaix type events where road tires might be better than cross tires.
    Thanks
    XC, Road, XXC, Endurance, Mtn, All-Mtn, Cross, Gravel, just go have fun on 2 wheels!
    Jan 2012
    For rain...
    Continental Grand Prix 4 Season
    Vittoria Rubino Pro Tech III
    although on pavement the 23mm-only Schwalbe Aqua is stickier than either of these.
    Mar 2013
    +1 for the conti grand prix 4season. Expensive but durable, roll well, flat protection, and one of the better grippingtires in the wet. Lower air pressure will help there as well.
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    The Duranos are really nice tires. Plush-riding, and good puncture resistance. Predictable when cornering. If you want to spend less, the Panaracer Pasela (non-TG) is a good option.
    GRAVELBIKE.COM - ride everything
    Manchester, England
    Reputation: Chocolatebike's Avatar
    Feb 2011
    I fitted some 28mm Marathon Supremes to my bike because my Pave SGs were cutting up too easily on winter roads. I also wanted a little more cushioning because of the pot-holes around here. It's a cross bike (On One Dirty Disco) but I use it mainly on the road with some canal tow-paths, gravel tracks and bridleways thrown in.
    While they're a bit heavier than some of the other tyres mentioned, the Supremes have been bomb-proof over ~1600 miles so far.
    Having said that, I've just got a new/extra set of wheels and I opted for 28mm GP4 Seasons on those (I wanted a lighter, faster tyre). As luck would have it I got a puncture on them today although I wouldn't blame the tyre since a piece of wire got through. I reckon it would have taken out most tyres except, perhaps, for Marathon Pluses.
    It was my own fault; I'd crunched through a lot of glass and I thought "I'm lucky not to get a puncture after that".
    Reputation: tarwheel2's Avatar
    I've been commuting on the same set of Conti GP 4 Seasons for several years. They are durable, relatively light weight and flat resistant. That said, they don't truly measure 28 mm wide unless you have wide rims like Velocity A23s or Dyads -- more like 26 mm on Open Pros and similar rims. Panaracer Paselas are a good inexpensive option but their rolling resistance is much higher than the Contis. I'm also curious about the Clement Stradas and might try them for my next set of 28s.
    Vittoria Rubino Pros are supposedly available in 28s but you don't see them very often. I've got Rubino 25s on one of my commuter bikes, and they have been great tires -- but again, they run narrower than their stated size. I've also got Vittoria Randonneur Hyper 32s on my touring bike, and they are very nice tires. Heavier than the other tires mentioned but not bad for 32s with low rolling resistance. I think they are available in 28s and are probably heavier than the Rubino 28s but also more durable.
    Aug 2011
    Not sure if these will be to your liking, but check out the Kenda Karv's 700x28, dirt cheap too (ebay)... and pretty durable. I have them as 700x25 as a beater/training tire and never had any issues with them yet.
    Reputation: mark4501's Avatar
    Jul 2007
    I've been using Continental GatorSkin 28mm since August 2012 and am very happy with them. Work well on crushed rock paths and perform nicely on pavement. When these wear out will likely get another set
    Oct 2009
    Schwalbe ZX Ultrema 700/28 ---- fast tire and surprisingly durable. I put a ton of winter training miles and three races (gravel/bad roads) on them --- no punctures. Much better riding than something like a gatorskin.
    Cyclist
    Reputation: Nater's Avatar
    Feb 2003
    Re: 700x28 tire for mixed riding
    Challenge Eroica 30mm
    Clement Strada LGG 28mm
    Jul 2011
    Quote Originally Posted by HEMIjer View Post
    Thanks
    I have Panaracer Pasela TG 28's on my bike for this purpose. Used it to do a local 79 mile ride with a good amount of dirt and gravel. Worked great.
    Reputation: The Moontrane's Avatar
    Nov 2005
    Quote Originally Posted by GRAVELBIKE View Post
    Just last week I learned that the Durano is available in 28mm. I've used the 25mm for a few years and find it to be a fantastic tyre.
    Ballan, we have a problem.
    Reputation: demonrider's Avatar
    Jul 2012
    I wish Vredestein made a 28mm Fortezza Tricomp tyre. Recently used the 23mm (which is the size of a Conti 25mm) in a half gravel half road race recently and was very impressed with it.
    But to answer the OP's post, I use 28mm Gatorskins for the same purpose and they seem to work fine although I'm coming to the conclusion that Conti tyres in general are harder, hence chip and tear more easily than more supple tyres like from Schwalbe etc.
    Argon 18
    Ridley
    Brodie
    Jul 2007
    [QUOTE= Much better riding than something like a gatorskin.[/QUOTE]
    Weaksister...out of curiosity, what is the negative to gatorskin tires?
    Quote Originally Posted by mark4501 View Post
    I'm not Weaksister, but can tell you a few negatives about Gatorskins. They are long wearing and have good rolling resistance, but also ride poorly, IMHO. I put some 25 mm Gators on my Gunnar Sport and they rode so harshly that I had to take them off. They were also extremely hard to mount on the wheel rims, the hardest of any tire I have every used. Finally, the Gator 28s are only available with wire beads, which are heavier than folders. Conti GP 4 Seasons have the same flat resistance and durability as Gators but are much lighter and nicer rider. GP 4 Seasons are simply a much better tire for about the same price.
    Idiot at large
    Apr 2010
    Have you still considered CX tires for hardpack?
    Like:
    Continental Cyclocross Speed
    Specialized Trigger
    Schwalbe Sammy Slick CX
    etc
    Granted, I have done some rail-trails on my road bike with Conti Grand Prix 4-season 700x25c.... not that fast though
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
  1. Who makes a good 700x28 tire?
    By cleon in forum Endurance Riding
    Last Post: 04-05-2014, 12:24 AM
  2. Economical (>$30) 120psi 700x28 or 32 commuter tire.
    By RoadLoad in forum Commuting, Touring and Ride Reports
    Last Post: 01-31-2013, 08:18 PM
  3. Putting a 700x32 tube into a 700x28 tire
    By Jim52 in forum General Cycling Discussion
    Last Post: 09-14-2012, 03:00 PM
  4. best 700x28 tire for milage and flat protection.
    By Buildingmaint in forum General Cycling Discussion
    Last Post: 09-08-2012, 04:07 PM
  5. 700X23-25 Tubes In A 700X28 Tire
    By JimOfOakCreek in forum Components, Wrenching
    Last Post: 12-11-2009, 02:05 PM
