Results 1 to 5 of 5
    Feb 2009
    Aero advantage between 58 vs 52 rims
    In your experiances. Is their a noticable aero advantage between a 52mm rim vs a 58 mm rim? Or do you need to go 68/80 deep before you have a true aero advantage over a 52mm or even a 45mm deep rim.
    Reputation: stevesbike's Avatar
    Jun 2002
    have a look at something like this from Hed (comparing standard, 40 and 60s and 90s
    http://www.hedcycling.com/wheels/jet6.asp
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Jan 2005
    The answer isn't as simple as depth of rim, though that plays a part. Other factors include rim shape, spoke count, spoke shape, tire used on a particular rim, probably others. That graphic from roues artisanales (sp?) that Zen links you to illustrates this.
    Angle of wind is also important as stevesbike's link illustrates.
    Jun 2002
    yes, if you take into account real-world conditions and wind angle, the Hed3 is really the best (if you're talking time trials)
    http://www.hedcycling.com/wheels/H3_clincher.asp
    in particular, it doesn't stall at high wind angles, but actually decreases drag.
