Results 1 to 6 of 6
    Reputation: sdeeer's Avatar
    Aug 2008
    Alchemy Elf Questions
    My elf has been 'dragging' a bit so I took axle off and cleaned it and regreased. I noticed that one bearing has some catches in it and the other one runs smooth.
    Is there an easy way to clean it further? How do you service the Elf bearings (can they be opened and cleaned or is that a nightmare? I used to clean my roller blade bearings as a teen, and it was a pain. Is there an online resource? Can you just pop them out?
    What is the approximate cost of replacement for one of those?
    And as far as preload tension, how far past 'hand tight' should you go. It seems like only an 1/8 of a turn (or less) is about right?
    Thanks!
    "The lower limit of dietary carbohydrate compatible with life apparently is zero, provided that adequate amounts of protein and fat are consumed."......http://www.nap.edu/openbook.php?reco...10490&page=275
    Feel free to PM me nutrition questions. I will answer them if I have time.....
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Call Jeremy at Alchemy Bicycle Works. No one will answer your questions more thoroughly than him:
    303.410.4985
    I wouldn't bother trying to take apart the actual bearing.....just replace it. They are really cheap. I forget exactly but it's less than $10.
    It takes 6900 series 10x22x6 mm bearings.
    Reputation: JimP's Avatar
    Dec 2001
    Quote Originally Posted by sdeeer View Post
    It sounds like you had too much preload tension. The skewer will compress the axle a little so you might need to start out at hand tight and then back off 1/4 turn or maybe more.
    Jim Purdy - Mansfield, TX
    Pitts Pilot
    Dec 2011
    Order new bearings and slap them in. Jeremy has posted some video on youtube. This one is a bit old but should help.
    Remove ELF axle and bearings - YouTube
    Feb 2006
    You don't go *past* hand tight. You need to loosen from there, so that you are left with just a hair of play with the QR clamped. You need loctite for the axle threads.
    You can try to clean and regrease a bearing in the hub by prying off the outer seal... but it's much better to just replace it. They are cheap and easy to replace. In your case it sounds like the bearing was damaged though, so you need to replace it anyway.
  1. First Ride on the Alchemy ORC-UL Hub
    By Zen Cyclery in forum Wheels and Tires
    Last Post: 05-14-2013, 08:15 AM
  2. R45 vs Alchemy
    By MTBDad in forum Wheels and Tires
    Last Post: 09-07-2012, 03:22 AM
  3. Alchemy Hubs?
    By JoelS in forum Wheels and Tires
    Last Post: 06-08-2010, 11:14 AM
  4. Alchemy ELF hub
    By mrob239 in forum Wheels and Tires
    Last Post: 05-03-2010, 05:30 AM
  5. Tune Mag 180 and Alchemy ELF
    By bolt30 in forum Wheels and Tires
    Last Post: 07-21-2009, 08:48 AM
