Results 1 to 2 of 2
    Sep 2012
    alloy disc road hubs
    alloy disc road hubs with 8-Speed 12 / 26
    when this is mentioned.
    does that indicate a certain width or type of hub ?
    i ask so when i order replacement wheels.
    i will chose the right set
    and they will fit without issue on a cyclocross bike.
    Wheel Builder
    Reputation: cfoster's Avatar
    Dec 2007
    Quote Originally Posted by loona View Post
    From the info you've provided, it's not possible to offer a definitive answer. Generally speaking, when someone takes the time to specify "Road", its assumed, (you know what that does), that the Road reference means a 130mm spaced/OLD rear hub. But rather than assume, if you can measure the spacing between the dropouts in your frame using a metric ruler, problem solved. You're looking for a measurement close to 130mm or 135mm. Our CX section offers both 130mm and 135mm CX disc wheel set options.
