Results 1 to 5 of 5
    Aug 2007
    Alpha Q CS10 and 700x28 tires
    Has anybody fit a 700x28 tire on an Alpha Q CS10 fork. Documentation shows 371mm from center of axle to crown of the fork. I have a Panaracer Ruffy Tuffy 28 mm that just rubs the fork.
    Thanks
    Jan 2009
    I ran Continental Gatorskins 28c with same fork no issues. I
    Reputation: The Moontrane's Avatar
    Nov 2005
    I use 27mm (labeled 25mm) tires with my QS10. There’s about an 1/8” clearance between the tire and the bottom of the fork crown. Might that Tuffy be larger than 28mm?
    Aug 2007
    I think the Ruffy Tuffy might be large for 28s, or at least not a small 28.
    Thanks I'll try the Gatorskins.
    Slow but not so steady
    Jan 2003
    My Mich Pro 2 25c fits tight but the Pro 2 is like others 28
    There is a fine line between a hobby and mental illness.
