Results 1 to 10 of 10
    Adventure Seeker
    Reputation: Peanya's Avatar
    Jun 2008
    Alto hubs? Hub choice overthinking
    Been pondering getting a lighter set of wheels for my roadie. Currently running Grail hoops on Hope Pro 4's. Got these to take on tough situations such as light trails and bike packing. They're tough as a tank, but the drag on the hub pawls is noticeable.
    Anyway, I've been going back and forth between I9 Road hubs and going back to Chris King. In searching for comparisons, I came across Alto. Never heard of them, but after reading them, they're impressive. I spoke to one of the guys there, and came away even more impressed.
    Any experience with these? Or, any experience in freewheel drag comparing I9 and CK?
    I have a single track mind
    changingleaf
    Aug 2009
    I have not used the Alto hubs, but they look like a standard 3 pawl design. Hope hubs have heavy springs and a tight seal around the freehub body which provides durability, but extra drag. I9 has lighter dragging pawls, but across more teeth. Chris King's entire 45 tooth ratchet drags, but fairly lightly.
    Lighter dragging hubs are:
    DT Swiss with 18 ratchet teeth lightly dragging
    America Classic has almost no drag except for one tiny spring that engages the pawls when it grabs the clutch.
    Shimano hubs have fairly low drag.
    Onyx hubs are silent, but do have noticeable drag.
    White Industries has 3 lightly dragging pawls.
    Quote Originally Posted by Peanya View Post
    I'd suggest that's all in your head. There's just no way anyone could perceive how much the pawls are slowing you down. Or if you're talking about spinning on the stand, who cares, that's got nothing to do with how they spin with a rider weight on them.
    Feb 2002
    Chain droop when coasting would be indicative of pawl (or more likely seal) drag. Whether that is significant on the road is another question, but clearly if the chain is not drooping then it truly is all in the head.
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    In some designs, significant chain droop means there's some binding going on. Many floating axle systems have a thrust washer in between the shell and the freehub. If that's missing you will get some binding or worse.
    If no droop, you're fine.
    Reputation: Lombard's Avatar
    May 2014
    The other solution to any freewheel drag is never stop pedaling.
    Seriously, is this really perceivable?
    'brifter' is a lame word.
    Free hub drag? Really? Definitely 'overthinking' it.
    I work for some bike racers
    and a bunch of skateboards
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Yeah? You try dealing with sequins getting caught in yours.
    Donald Trump has never had a wife he didn't cheat on.
    Adventure Seeker
    Jun 2008
    Guilty as charged. I'm mainly focused on quality engagement and total weight savings. I guess I'm just trying to avoid those cheap designs that don't always catch where they're supposed to (happens on my MTB, and happened on an older wheel).
    Made up my mind finally anyway, will post when I get to try the new wheels out!
    Jan 2009
    So what’s the word?
    Report?
    KTM 300XC- This must be what it is like to be on Crack without the side effects!
    Litespeed Vortex
    Ellsworth Truth
    Good riding to you!
  1. Hubs ... hubs and more hubs
    By StillKeen in forum Fixed/Single Speed
    Last Post: 04-11-2006, 01:23 PM
  2. When are best months to buy road bikes? Palo Alto,CA
    By samsation7 in forum Beginner's Corner
    Last Post: 10-23-2005, 11:24 AM
  3. Input on WTB Camino Alto??
    By bikesforpeace in forum Wheels and Tires
    Last Post: 09-08-2005, 08:18 PM
  4. Sequoia Century (Palo Alto, June 5)
    By johnny99 in forum Northern California
    Last Post: 05-23-2005, 10:21 AM
  5. Palo Alto - Route Suggestion/Recommendation
    By Squizzle in forum Northern California
    Last Post: 02-17-2005, 02:11 PM
