Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
  1. #26
    wim
    wim is offline
    Feb 2005
    the bigger the tire the lower the rolling resistance
    Unless you put in the missing piece "at identical pressures," this is pretty much bunk when made as a general statement.
  2. #27
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by wim View Post
    Yep, I know, and that was stated in the link. I didn't paste and copy the whole link because I figured that if anyone was interested all they had to do was open the link.
    From the link.
    The bigger the tire, the lower the rolling resistance at the same air pressure. When you run lower air pressures, the differences get even bigger.
    Too old to ride plastic
  3. #28
    Sep 2007
    Yes
    Yes
    No
    How to heck do you figure someone could measure handling with a powermeter or clock?
    Faster handling equals quicker times over the same course under the same power.
  4. #29
    um, no, it doesn't.
  5. #30
    Sep 2007
    um, no, it doesn't.
    Then why strive for faster handling?
    If the bike handles faster it'll get you through the corner faster, so how doesn't that translate to quicker times over the same course? How many times do you go through corners in a crit, and if your bike is faster handling than your competitors you make time in every corner and if your power output, handling skills and tactical savy are equal to theirs, you win.
  6. #31
    First off not every ride or race is a crit with sharp corners but going fast though corners and having a fast handling bike are not the same things. I have no interest in arguing about it though.
  7. #32
    Sep 2007
    I didn't realize that we were arguing.
  1. 23mm tire on 25mm mm rim or 25mm tires on 20.5 rims - questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 01-09-2017, 05:37 AM
  2. Any issues running an 18-25mm tube in a 28mm tire?
    By lacofdfireman in forum Wheels and Tires
    Last Post: 11-22-2016, 05:37 AM
  3. 28mm tires
    By daniell in forum Wheels and Tires
    Last Post: 12-13-2015, 05:26 PM
  4. Why not 28mm tires?
    By Rogus in forum Wheels and Tires
    Last Post: 11-05-2015, 02:05 PM
  5. Colored 25mm-28mm tires
    By wily in pacifica in forum General Cycling Discussion
    Last Post: 02-09-2004, 05:14 PM
