Results 1 to 9 of 9
    bas
    bas is offline
    Jul 2004
    Bent up my spokes
    Oops.. not sure if it this happened before or after I lost my rear derailleur. (chain did jam in spokes, but I didn't torque it any).
    Krysium SL rims.. I see some used pairs on Ebay around $280.. need 9 speed though. I do have a spacer on there, so I think it's an 8/9.
    Spokes feel tight and rim still looks true. Going to check out of round, but I think that is still good by eyeballing it on the bike before.
    I probably shouldn't ride this?
    I guess I'll see how much the shop wants to rebuild.
    Just put it on the truing stand. A little more wheel wobble than I want. Front is within spec.
    Oct 2013
    I see a new wheel in your future, that wheel isn't worth rebuilding, IMO.
    BANNED
    bas
    bas is offline
    Jul 2004
    You might be right.
    I'm guessing this is a 2004-2007 model Krysium SL spoke.
    New spokes are no more, and the drive side used spokes are sold out.
    https://www.mavicparts.com/collections/mavic-road-spokes/products/mavic-ksyrium-sl-zicral-silver-spokes-2004-2007?variant=1194581573
    I did find a used rear rim that looks in good shape - but missing one non-drive side spoke.
    Oct 2013
    I have a Elite from 2001 front & rear + handful of spokes.
    BANNED
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by bas View Post
    8, 9, 10 speed are the same freehub width. You could even use an 11-speed if you have the extra spacer.
    bas
    bas is offline
    Jul 2004
    Thanks.
    I guess I'm looking at the Mavic, Zipp 30, or Ultegra.
    https://www.performancebike.com/Comp...Page%3Dcompare
    May 2014
    Thanks.
    Yes, they say "10/11 speed". They all have an 11-speed freehub, but can be used with an 8, 9 or 10 speed cassete with a spacer.
    Feb 2002
    If you can true the wheel then it is most likely OK to ride for a long time. The worst case scenario is that the spoke breaks and you have to replace the wheel.
    Let this be a lesson for you about wheels with proprietary spokes. If that had happened to me, I would have replaced the spoke when I got home from the ride, trued the wheel, and never given it another thought. But that is because I have spokes left over from when I built the wheels and there is nothing proprietary in my build.
    Russian Troll Farmer
    Sep 2016
    I see 3 or 4 spokes bent right at where they flatten (i.e., at a 'stress risor'), so YES, those spokes are unsafe! Replace them!
    "L'enfer, c'est les autres"
  1. Bent bent.
    By BentChainring in forum The Lounge
    Last Post: 03-29-2009, 06:59 PM
  2. Get Bent, Bent...
    Last Post: 09-18-2008, 09:27 AM
  3. Bent Davis Phinney Bent Steel Dropout
    By powerdan5 in forum Serotta
    Last Post: 11-16-2006, 03:58 PM
  4. deraillier got pushed just into spokes and now looks bent
    By oldbikes in forum Bikes, Frames and Forks
    Last Post: 07-25-2006, 06:58 PM
  5. Excessivly tight spokes = bent rim
    By TI_roadracer in forum Components, Wrenching
    Last Post: 05-20-2006, 05:48 AM
