Results 1 to 5 of 5
    Reputation: Inspector Gadget's Avatar
    Apr 2002
    Better Gravel Rim Option?
    I'm looking to build a set of disc wheels for gravel grinding. I'm looking at Stans Grail or Alpha 400 (a little lighter). Is the Grail rim significantly stronger? I'll be running 700x40 semi slicks most of the time and do tend to bomb down hills with a bit of reckless abandon. I realize the Alpha 400 is basically designed for rim brakes. However, I've built numerous road disc wheels using Alpa 340s with no problems. Thanks in advance for your thoughts.
    Reputation: Srode's Avatar
    Aug 2012
    If you are thinking tubeless, I don't believe Stans rims play well with all tubeless tires.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    changingleaf
    Aug 2009
    Definitely go with the Grail over the Alpha 400. It's wider and better for tubeless. The Alpha has a bead seat that is too narrow and the tires will not stay seated when you let the air out. Some tubeless tires are tight on Stan's rims but still work fine. The new Pacenti Forza disc is an excellent option as well. It has an asymmetrical spoke drilling for better spoke tension left to right. I've built wheelsets with both of these disc rims and they are great.
    Dec 2016
    Quote Originally Posted by Inspector Gadget View Post
    I put a set of Nox Skyline on my Stigmata. They are awesome and my fat ass appreciates any help I can get on the inclines
    Feb 2013
    When I was looking for some new wheels I was looking at the Stans options and advised by the wheel builder that the Pacenti SL25 was probably a better (stronger) option.
  1. Gravel Bike wheel q: Stan's ArchEX on gravel bike
    By stuarttx in forum Wheels and Tires
    Last Post: 03-23-2017, 06:53 PM
  2. Gravel Grinding: There is about to be more gravel to ride...
    By Erik_A in forum General Cycling Discussion
    Last Post: 07-13-2016, 04:42 AM
  3. NUCLEAR: Option
    By Bill2 in forum Politics Only
    Last Post: 07-17-2013, 09:38 PM
  4. Another BB adapter option.
    By DS1239622 in forum Specialized
    Last Post: 03-22-2013, 09:54 AM
  5. Private Option...ummm...Option.
    By physasst in forum Politics Only
    Last Post: 10-01-2009, 10:18 AM
