Results 1 to 10 of 10
    Apr 2012
    Bikehubstore SL210 Hub -- any experience out there?
    I was looking at an e-bay wheelset offering and he uses this rear hub in a 16:8 triplet lacing. https://www.bikehubstore.com/SL210-p/sl210.htm
    Anyone have any experience or thought on this hub?
    scott s.
    Reputation: Mackers's Avatar
    Dec 2009
    This is just a regular hub drilled for triplet lacing, not a hub actually designed for triplet lacing.
    You'll gain balanced-ish spoke tension left and right but lose lateral stiffness.
    The hub itself is cheap and cheerful. Design is simple. Bearings are relatively small and longevity may be problematic. Mine came with low quality Enduro bearings. I guess you get what you pay for.
    changingleaf
    Aug 2009
    As stated, the bearings are relatively small and I wouldn't recommend this to larger riders. I've had a couple quality control issues with these, but you can't beat the price and weight. I'm ambivalent about triplet lacing and most rims are not designed for it.
    I built up a set for a 16:8 for a friend of mine friend mine. They have worked well for him.
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    I prefer to use this hub with a standard 1:1 spoking and an offset rear rim like Pacenti Forza
    Apr 2012
    Sorry for getting back to this thread late. I am more familiar with DTSwiss hubs but see many builders suggesting White Ind T11. I guess I don't need the cheapest hub and don't see a reason not to go with a 24 spoke 2x build.
    Thanks all for taking the time to respond.
    scott s.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by scott967 View Post
    scott s.
    DT Swiss vs. White Industries? I would go with White Industries. They have a Ti freehub which will be less prone to cassette gouging than the DT hubs.
    FTR
    FTR is offline
    Burn baby, burn.
    Reputation: FTR's Avatar
    Sep 2006
    I now of so many WI failures it is not funny.
    All developed play that could not be adjusted out.
    May 2014
    Quote Originally Posted by FTR View Post
    Seriously? Where have you heard of problems with WI?
    FTR
    FTR is offline
    Burn baby, burn.
    Sep 2006
    My own, 2 friends and discussions with my LBS.
  1. FS: BHS SL210 rear hub, black, 24 hole
    By 491025 in forum Classifieds
    Last Post: 09-21-2016, 07:36 PM
  2. BHS Sl210 Hub dissassembly/servicing
    By fronesis in forum Components, Wrenching
    Last Post: 08-17-2015, 02:39 PM
  3. BikeHubStore experience
    By John844 in forum Wheels and Tires
    Last Post: 05-29-2015, 04:48 AM
  4. BikeHubStore Hub Preload
    By Helms in forum Wheels and Tires
    Last Post: 02-16-2014, 03:41 PM
  5. BikeHubStore hub picture thread
    By nsk1 in forum Wheels and Tires
    Last Post: 09-28-2012, 07:23 AM
