Results 1 to 10 of 10
    jwk
    jwk is offline
    Jun 2011
    Cannot Inflat tire- Removable Presta Valve will not stay open!! Help
    I just recently put removable presta valve core inner tube and I now cannot put air into my tires. I opened the valve all the way and locked it by giving it an extra tug, still cannot pump air. I get pressure but no air will go in tire. Does anybody know what is causing this? Bad inner core valve?
    A wheelist
    Reputation: Mike T.'s Avatar
    Extra tug? No, you unscrew the little thingamajig and then press it inwards to break its seal and then you're good to inflate.
    Mike The Bike's home wheelbuilding info for Newby motivation.
    I'm not cranky; I just have a violent reaction to stupid people.
    jwk
    jwk is offline
    Jun 2011
    Quote Originally Posted by Mike T. View Post
    I will definitely try that! thanks
    A wheelist
    Quote Originally Posted by jwk View Post
    When you hear a goodly "pssst" you know you've done it. With a tube with no air in it, you won't hear the "pssst" of course but the seat could be stuck and it need of unseating. So - always press the stem inwards before inflation.
    And always re-tighten the thingamajig too - air pressure should make the seal but it doesn't always, as I found out last summer.
    jwk
    jwk is offline
    Jun 2011
    I also forgot to include, when I tried unsuccessfully to get air into my tires yesterday, they were new so I am now thinking not having any air in the tires, the valves needed to be primed. Now that they are fully inflatted, getting air is now easy and the pressure keeps the valve open. I think when there was no pressure, it did not keep the valve open
    A wheelist
    I don't agree. Air pressure keeps the valve seated and sealed. When the tube was new the valve seat was stuck and it needed to be manually separated.
    I have a tip for you. With any new (or empty tube not already inside a tire), unscrew the nut, press the stem to unseat and, by mouth, insert enough air to slightly inflate the tube. This will make installation into the tire easier, plus you will know that the seat seal has been broken.
    'brifter' is a lame word.
    wrong. air pressure inside the tube keeps both presta and schrader valves CLOSED, not open.
    2012 Trek Cronus Ultimate w/ SRAM Red Black
    2010 Cervelo T1 sprint bike
    2011 Cervelo P2 pursuit bike
    FMF 24" cruiser
    Bianchi Pista road fixed gear
    1949 Columbia 26" cruiser w/ SRM & fenders...and rust
    '05 Suzuki DRZ400SM
    Pullin my trigger.
    Nov 2008
    Jeebus, I am con-fuzed.
    I need a beer.
    Cycling should be fun. The rules are stupid. Ride because you love to ride. --QED
    Pullin my trigger.
    Nov 2008
    And whatever you do dont stick it in your eye.
    jwk
    jwk is offline
    Jun 2011
    Thanks! I have learned so much. I am primarily a runner but this season I plan on getting more into cycling as I am tired of running
