Results 1 to 6 of 6
    Jul 2009
    carbon wheels or aluminum
    I here a lot of people say that carbon is faster, but why if they weigh the same?
    Jan 2005
    If the rims are the same width/depth the CF would not be any "faster", but most CF rims are wide or deep and are made to be more aero. More aero=faster if you got the engine.
    "The problem with losing your mind is that by the time you realize it's gone, it's too late to get it back."
    Walk in the Woods by Bill Bryson
    Boyd Cycling owner
    Reputation: coachboyd's Avatar
    Jan 2008
    There are three forces that slow you down when you are riding. Resistance, aero, and gravity.
    Resistance forces are things like tires hitting the ground, bearings, and chain. Rolling resistance is the biggest of these items (tire contact with pavement) and it's consistent wattage no matter what speed you are going, usually a very small percentage of your overall wattage.
    Gravity forces is what slows you down when you go uphill. Here is where weight matters. When you are going uphill a lot of your wattage is used to overcome gravity, when you are going downhill there is negative forces for gravity.
    Aero forces are used to cut through the air. The wattage used to overcome this exponentially rises with speed. So the faster you are going, the more being aero will help you. Wheels are a very small amount of being aero, but when you have worked on position or to get that extra couple of percent, aero wheels can definitely help. Even though they are slightly heavier than lightweight low profile wheels the majority of forces you are trying to overcome (unless you are purely climbing) will be to cut through the air. When you are climbing the speeds are low enough that you are not overcoming aero forces, and that is where having a lightweight wheel is an advantage.
    www.boydcycling.com Handcrafted Revolution
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Keep in mind not all carbon is created equal.
    If your willing to spend the $$$, carbon can be a great option. But many manufacturers try to bring you "budget" carbon which sounds great but has many pitfalls.
    So all in all, if moneys an object, go with a nice alloy hoop.
    A wheelist
    Reputation: Mike T.'s Avatar
    What coach Boyd said plus this -
    To answer your question exactly - no, there is no built-in speed in carbon material over aluminum.
    Mike The Bike's home wheelbuilding info - dedicated to providing Newby wheelbuilder information and motivation.
    I'm not cranky; I just have a violent reaction to stupid people.
    Reputation: Clipped_in's Avatar
    May 2011
    Quote Originally Posted by coachboyd View Post
    Nice post!
    Ride lots!
    Eddy Merckx
  1. Steel vs. Aluminum vs. Aluminum w/Carbon Fork?
    By JazzComp in forum Beginner's Corner
    Last Post: 05-04-2013, 10:01 PM
  2. Carbon Or Aluminum Wheels
    By podilato1 in forum Wheels and Tires
    Last Post: 11-09-2010, 05:18 PM
  3. Replies: 11
    Last Post: 07-30-2006, 01:55 PM
  4. Replies: 1
    Last Post: 07-16-2006, 10:38 AM
  5. Brake pads for carbon and aluminum wheels?
    By outofthesaddle in forum Wheels and Tires
    Last Post: 09-30-2005, 12:17 PM
Sea Otter Classic
Contest
