Results 1 to 10 of 10
    Jun 2015
    cassette changing question
    So I have a set of 11 speed RS11's and I want to put a 9 spd cassette on. If I put that cassette on the wheel will I need to also have the wheel spokes adjusted to even it out and make it run correctly on my frame?
    a real member's member
    Jul 2016
    only if you change the o.l.d. will you need to redish the wheel.
    Jun 2015
    Ah ok,Yeah the LBS guy made it sound like I'd have to redish the wheels no matter what. Maybe go so far as to re-build my wheel.
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    Just put on your 9s cassette with the 11s 1.85mm spacer and ride away ...... after you change the chain that is....
    With bicycles in particular, you need to separate between what's merely true and what's important.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by dcgriz View Post
    This.
    Why would you need to re-dish the wheel? The size of the freewheel does not change. They are 11-speed wheels which, as DC stated, can be used with an 8, 9 or 10 speed cassette as long as you place an adapter to fill the gap.
    -- Warren Buffett
    Feb 2002
    Quote Originally Posted by LGRider View Post
    For entertainment, go back to the LBS and have them explain to you how it is that if you don't change the length of the axle in the hub and/or change the spacers on the axle, how would it be that you would need to redish the wheel. You either misunderstood or your LBS got confused or they REALLY don't know what they're talking about.
    Russian Troll Farmer
    Sep 2016
    If your LBS guy REALLY said that, then he took you for a patsy and was trying to shake some $$ out of you..
    "L'enfer, c'est les autres"
    A wheelist
    Reputation: Mike T.'s Avatar
    Or if he thought that a re-dish was truly needed he doesn't deserve to be fixing bikes.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilder's with motivation, information and resources.
    Everything above, up to that blue line, is IMO IMO.
    May 2014
    Quote Originally Posted by Mike T. View Post
    This is most likely the case. Or you talked to one of the salespeople who has never fixed a bike, not one of the mechanics.
    -- Warren Buffett
    Jun 2015
    Yeah this is what I believed I could do and everything I looked up pointed to me being able to do this.
    IDK if hes a sales guy, mechanic or a little of both TBH. I explained it pretty clearly and its not the hardest bike concept to grasp So he may have just tried to up sell me since all I went in for was the 1.85 spacer. That or hes not that great of a mechanic. Either way it doesn't fill me with confidence in their ability's or honesty there.
  1. Changing cassette Q
    By Norboo in forum Components, Wrenching
    Last Post: 05-25-2010, 03:33 AM
  2. changing out the cassette
    By notwist in forum Beginner's Corner
    Last Post: 09-06-2009, 06:17 AM
  3. cassette changing
    By kmunny19 in forum Components, Wrenching
    Last Post: 03-14-2009, 07:43 AM
  4. Cassette Changing
    By seattle in forum Beginner's Corner
    Last Post: 06-07-2006, 05:16 AM
  5. changing a cassette
    By by666 in forum Components, Wrenching
    Last Post: 06-06-2006, 05:16 PM
