Results 1 to 6 of 6
    Reputation: Lombard's Avatar
    May 2014
    Centerlock Disc Brake QR Hubs on a Rim Brake Bike
    Hi all wheel aficionados!
    Is there any reason you can't use disc brake QR hubs with rim brake rims? I am thinking if nothing else, rear spoke tension disparities will be less.
    The only disadvantage I can think of to doing this would be weight, though it's not a whole lot.
    Thanks!
    'brifter' is a lame word.
    Will you be able to get them in the frame? If they're 135 and the frame is 130 probably not a big deal.
    I work for some bike racers
    and a bunch of skateboards
    May 2014
    Oooops! OK, I knew TA disc spacing was wider (12x142), but didn't realize QR disc spacing was wider as well. At least the front would work, LOL! Nevermind!
    Feb 2012
    There are some 130mm disc brake rear hubs, but they are a bit obsolete now.
    (I ordered some Novatec 130mm disc hubs for a 20" kids bike disc-brake conversion I am doing.)
    Also, it might be worth mentioning that 142 rear spacing is, counterintuitively, the same as 135. Slightly over-simplifying, but it is basically a difference of how the hubs are measured.
    Reputation: 4slomo's Avatar
    Feb 2008
    A front disc hub will require dishing the front rim, and would be less strong than on a non-dished rim brake hub. The rear hub geometry would be less dramatic of a change.
    May 2014
    Quote Originally Posted by 4slomo View Post
    It is true that a front disc wheel requires dishing, but it is not anywhere near as much of a dish as a rear rim brake wheel. Less strong? In theory, yes. But really not enough of a spoke tension disparity to make a difference.
    A rear disc brake wheel actually requires less of a dish as a rear rim brake wheel.
  1. Disc Rotors - Centerlock or 6 Bolt?
    By Lombard in forum Components, Wrenching
    Last Post: 11-27-2017, 07:19 PM
  2. Mavic Hubsets for 6-bolt to Centerlock Conversion?
    By PoorInRichfield in forum Wheels and Tires
    Last Post: 02-13-2017, 08:22 AM
  3. DT Swiss 240s Centerlock QR to 15mm thru axle
    By deviousalex in forum Wheels and Tires
    Last Post: 06-05-2015, 09:56 PM
  4. Centerlock rotors with BB7
    By spookyload in forum Cyclocross
    Last Post: 03-12-2015, 08:47 PM
  5. recommend me a 11 speed centerlock disc hub
    By reptilezs in forum Components, Wrenching
    Last Post: 03-27-2014, 05:16 PM
