Results 1 to 5 of 5
    Reputation: PixelPaul's Avatar
    Oct 2004
    changing shimano free hub to campagnolo
    I have a set of Fulcrum racing 5 wheels with a shimano/sram freehub. I would like to use them on a campagnolo equipped bike. Is it as simple as changing out the freehub to a campagnolo compatible one?
    Jan 2010
    If it's 11-speed, just use Shimano cassettes.
    But yes, if you want to swap to a Campy freehub it's very simple. Just remember that the freehub retaining nut is reverse threaded. Once that is off the freehub just swaps over.
    All this only applies to post 2006 hubs. Pre-2006 you need to change the spindle as well.
    There's sometimes a buggy.
    One.
    Oct 2004
    I've read conflicting reports about using campagnolo levers/rear derailleur with a shimano cassette? but maybe this was for 9/10 speed? and you're saying 11 speed should be ok?
    Jan 2010
    Quote Originally Posted by PixelPaul View Post
    Yes, the compatibility between 11-speed cassettes has been widely tried and discussed for many years now. Ever since Shimano followed Campy's lead.
    like this
    So, we started swapping wheels between three bikes 11 speed bikes (one SRAM, one Shimano and one Campagnolo) on the workstand. It presented no problems whatsoever; you could get a decent shift with any 11 speed wheel on any 11 speed bike in the stand. However, what works on the workstand may not work so well under actual riding conditions, when torque and weight are applied. So, outside I went with these combinations. Except for the usual niggling problems that occur when swapping one brand of wheel for another, requiring derailleur adjustments to account for cassette placement, the various combinations worked fine.
    So, in conclusion, I concur with Leonard Zinn’s findings that a Campagnolo wheel works fine with Shimano or SRAM shifters, and that the reverse is also true. You just have to make sure you adjust the derailleur stops to match up with whatever wheel you are using for things to be smooth. So, barring spacing problems mentioned above (that we can usually permanently fix), riders no longer have to be concerned about using their Campagnolo wheels on a Shimano or SRAM bike. This simplifies matters and can be a real boon for those with multiple bikes with multiple components !
    Campagnolo, Shimano and SRAM 11 Speed Wheel Compatiblity
    and this Drivetrain compatibility hidden in plain sight | VeloNews.com
    One.
    Oct 2004
    wow, that's great news. I appreciate the response and the links. thanks.
  1. Changing to Campagnolo
    By tihsepa in forum Wheels and Tires
    Last Post: 08-04-2013, 04:06 PM
  2. Changing 8-speed Shimano cassette to 10 speed Campagnolo
    By igorZ in forum Components, Wrenching
    Last Post: 04-20-2010, 08:55 AM
  3. Anyone know if Shimano is changing the R300
    By DIRT BOY in forum General Cycling Discussion
    Last Post: 08-07-2008, 08:16 AM
  4. Changing the free hub on a SL3 form Shimano to Campy
    By azdroptop in forum Wheels and Tires
    Last Post: 12-04-2006, 04:00 PM
  5. Carbon-free Campagnolo Compact crankset?
    By mvetsch in forum Components, Wrenching
    Last Post: 09-26-2004, 01:56 PM
