Results 1 to 8 of 8
    Aug 2002
    Convert 2006 DV Stratus Clincher from Campy to Shimano
    I am looking at picking up a set of '06 Stratus clinchers. They are currently Campy and I need Shimano - does anyone know if it's a simple as a new freehub or do these wheels need to be re-dished? I did a search but didn't see an answer to this one...
    Oct 2005
    I believe 06 wheels have the Hadley made hubs. You will be able to tell by the titanium freehub body and it says Reynolds on the hub body. The White Industries hubs have the ti freehub but not the Reynolds name. If it is a Hadley hub you will need to find out freehubs are still available.
    Aug 2002
    Ligero - Thanks for the good info. Assuming it's a White Ind hub or that a Hadley freehub is available, would a re-dish be required for either of those?
    Oct 2005
    If it is a White Industries then yes it will need to be redished. It is a Hadley hub I am not sure but I am going to say yes that it will most likely need to be redished.
    Aug 2002
    Thanks
    The hadley hubs do require a redish as well.
    Aug 2002
    Thanks - that's probably more work that I want to do for these wheels.
    Every little counts...
    Reputation: Spunout's Avatar
    Aug 2002
    2 parts, a new freehub and a new left-side axle cap. Half of a turn on each spoke will re-dish the wheel (Campy freehub needs more dish).
