Results 1 to 8 of 8
    passive/aggressive
    Reputation: rockcrusher's Avatar
    Sep 2005
    Cracking spoke eyelets DT SWISS RR1.1
    I have a set of RR1.1s that I commute on and was just going over the bike and noticed all the rear drive side spoke eyelets are cracking and pulling out. I built them to spec tension and have about 1500miles of commuting on them. Anyone had a problem with this rim or is it just a byproduct of riding rough roads and commuting? TIA
    Bean
    kytyree
    Guest
    I had similar trouble with one a while back, don't know how old yours is, but I've read that they made some changes to the current ones to address this. Then again most alloy rims are susceptible to that to some degree, though I haven't had any other fail in the manner that one did on me.
    passive/aggressive
    Sep 2005
    Quote Originally Posted by kytyree
    hmm they are probably 4 years old maybe. I haven't done a ton of riding on them because i was using another bike for commuting for awhile but recently have sunk 1000 miles of commuting into them this summer.
    At least it is good to know that if I replaced with same it will hopefully be alleviated.
    Bean
    kytyree
    Guest
    Look as well at the eyelets, for a while you'd see those listed as single eyelet and also double eyelet. That may have been part of the changes, but I'd pick up the doubles if I could.
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Replace... With Kinlins...
    passive/aggressive
    Sep 2005
    Quote Originally Posted by Zen Cyclery
    kinlins?
    got it like velocity deep v's although looks like they are lighter which would be nice. Eyeleted?
    Bean
    Mar 2009
    Velocitys would be fine but they are a bit heavier than the Xr300. Between the two you cannot go wrong.
    Oct 2008
    I've got 4000+ rough miles on mine and they are fine, but they were new this year.
Sea Otter Classic
Contest
