Results 1 to 9 of 9
    Russian Troll Farmer
    Sep 2016
    Cycling computers and tubulars
    So, my 2 computers come with a long list of diameters for different tire sizes, but gives only 1 diameter for tubulars in general. I have 3 tubular wheelsets, one running 22mm tires, one running 24mm, and one running 27's. Is there any formula for calculating tubular diameters?
    "L'enfer, c'est les autres"
    (Clincher diameter x 1) - (insignificant difference between clincher and tubular x 0)
    Apr 2011
    Mark the tire, mark the floor, line up the 2 marks, rotate tire one rev, mark floor and measure.
    Nov 2014
    I suggest trying your best setting guess then comparing your total ride distance from your GPS.
    Reputation: Srode's Avatar
    Aug 2012
    some Garmin's will auto calibrate the speed / distance from GPS information and your wheel sensor revolutions - don't know how accurate it is though.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Dec 2006
    Quote Originally Posted by GKSki View Post
    Not everyone rides with GPS. I'm one of them.
    I determine wheel circumference by measuring from the floor to the axle. I subtract 1mm to account for tire compression (which may or may not be accurate but it's better than nothing), then multiply by 2, then by pi.
    I find the numbers in the set up manuals to be markedly different than my measured and calculated numbers. For instance, the 700x23 tire on my road bike measures out to 2098mm while the manual suggests 2133mm.
    I should use the manual's number because then, I'd be faster.
    Sep 2016
    Quote Originally Posted by Peter P. View Post
    Well, if you REALLY want to go faster, try putting 2 pickup magnets on your wheel.....
    Feb 2002
    You start with the methods outlined here (measure rollout, and for a more accurate meansurement, measure rollout with a rider on the bike). And then you do the obvious calibration. One possibility is the GPS mentioned, though there are reasons for GPS to be innacurate particularly if you have a route that is very hilly & twisty. The best calibration method is to find a road or trail will mile markings. Ride as long a distance as possible (10 miles is good, 20 is much better) and compare the reading you get from your computer with the actual mileage. Correct your wheel diameter input by the ratio of actual miles to computer miles. It's by far the most accurate calibration you can do. Guessing wheel diameters is a poor third choice.
    Sep 2016
    Well, I'm going to bring in the front wheel from each wheelset to work, get out the 36" verniers, clamp the jaws really tight against my tires, and have somebody read the diameter.
  1. GPS Computers: Speed / distance variances vs traditional bike computers
    By ishmaelmuscat in forum Components, Wrenching
    Last Post: 03-16-2012, 08:36 PM
  2. cycling computers and full 32mm bars pro vibe
    By samh in forum Components, Wrenching
    Last Post: 01-30-2011, 08:50 PM
  3. cycling computers and non-tapered 32mm handlebar?
    Last Post: 01-28-2011, 02:56 PM
  4. Need advice on cycling computers and clipless pedals/shoes
    By BTurn7 in forum Beginner's Corner
    Last Post: 05-30-2006, 07:24 AM
  5. Computers, anyone know fr*ken computers...
    By SheSpeeds in forum General Cycling Discussion
    Last Post: 06-15-2004, 09:49 AM
