Results 1 to 6 of 6
    wut?
    Reputation: Clipped_in's Avatar
    May 2011
    De-burring nipple holes?
    What tool do you use to de-burr nipples holes when required?
    There I was...
    Feb 2002
    Quote Originally Posted by Clipped_in View Post
    On the rare occasion I have needed to do this, I simply used a phillips head scredriver. If you are talking about deburring the holes in the rim's spoke bed, then a large drill bit works well - you do it by hand just twisting the bit with your bare (or gloved) hands.
    wut?
    May 2011
    Thanks for the reply Kerry. Just as I had envisioned it...
    There I was...
    Feb 2003
    I use a deburring bit similar to the 1/4" size in this set: https://www.amazon.com/Degree-Indust...=deburring+bit , I bought it at an Ace Hardware years ago but can't find a photo. I put it in my electric drill. It only has a single cutter and no sharp point. It will not enlarge the hole in the spoke bed, only give it a uniformly smooth edge.
    Russian Troll Farmer
    Sep 2016
    A metal deburring knife is best, but an exacto blade will do on both aluminum and CF.
    "L'enfer, c'est les autres"
    Aug 2005
    Quote Originally Posted by cdhbrad View Post
    Last time I did this, I just used a plain drill bit a little larger than the hole diameter. Hand held with very gentle pressure, of course.
  1. Rims 16 holes and hubs 32 holes
    By nyanyin in forum Wheels and Tires
    Last Post: 05-21-2014, 02:22 AM
  2. Zipp rim - spoke nipple holes
    By tom_h in forum Wheels and Tires
    Last Post: 11-02-2010, 07:51 AM
  3. Replies: 0
    Last Post: 07-02-2009, 06:51 PM
  4. MA3 Cracked/Nipple pull through...can I ride until ...?
    By MisterMike in forum Components, Wrenching
    Last Post: 08-18-2004, 04:40 AM
  5. MAVIC CXP33 + Ultegra F & R Hubs + Nipple Sz?? + Spoke Length ??
    By r_u_armstrong in forum Components, Wrenching
    Last Post: 08-09-2004, 07:12 PM
