Results 1 to 20 of 20
    Apr 2012
    Didnt get what I thought I did. Dura ace c24 CL vs TL with clincher tires
    I wanted the CL model wheels because I am only going to use clincher tires. I got the TL model which says road tubeless on the side but they put clincher tires on it. The LBS where I bought it says the TL wheels are better because I can run them without tubes (no rim tape) or clinchers and I guess I could also do tubulars if I wanted. they put on Conti GP4000s tires.
    Is there any disadvantage to what I ended up with? They will get me the CLs but is that necessary?
    2013 Pinarello Dogma 65.1 SR EPS
    2012 Cervelo RS
    2013 Felt F65X CX bike
    2012 Cannondale Flash Alloy 1 29er
    Aug 2006
    the TL with clincher tires will lose their structural integrity with exposure to direct sunlight
    LANCE ARMSTRONG 2009 NEVADA CITY CHAMPION
    Apr 2012
    So if I were to ride early or on only overcast days would I be okay? How about the wheels?
    2012 Cervelo RS
    Fecal indicator
    Reputation: Oxtox's Avatar
    Aug 2006
    the only difference I'm aware of between the CL and TL rims is weight.
    CLs are listed as 1385g, TLs are 1458g.
    eff all y'all...
    'brifter' is a lame word.
    Quote Originally Posted by Donn12 View Post
    you can use clincher tires ONLY. regular or tubeless, doesn't matter. obviously to go tubeless, you need tubeless tires. you can NOT put tubulars on those wheels. after you wear out the GP4000's try some tubeless tires...you might like 'em.
    2012 Trek Cronus Ultimate w/ SRAM Red Black
    2010 Cervelo T1 sprint bike
    2011 Cervelo P2 pursuit bike
    FMF 24" cruiser
    Bianchi Pista road fixed gear
    1949 Columbia 26" cruiser w/ SRM & fenders...and rust
    '05 Suzuki DRZ400SM
    T K
    T K is offline
    wasssabi
    Reputation: T K's Avatar
    Feb 2009
    Awww, come on! Let him try glueing some tubies on those. That would make for a fun thread.
    downhill quickly
    May 2007
    Quote Originally Posted by Oxtox View Post
    ...and that's why I went TL's at at 16/20 spoke count. Those 7900 C24's TL's are probably the best box period. Stiff for climbing +15 %, nimble and sure foot going down same and you have plenty of tube and tubeless options. Frankly, I'm amazed at the sure fire spin and quiet glide of those wheels ( I run Conti gp4000s on them now)...and I have Zipp 404 Firecrest Clinchers to compare them with
    Master debator.
    Reputation: nOOky's Avatar
    Mar 2009
    If you researched and wanted the CL's for your use then that's what you should have gotten. What's the price difference?
    Apr 2012
    I actually thought TLs were for tubulars and was not familiar with tubeless....knowing what I know now, TLs are fine, maybe even better if I want to try tubeless at some point. The TLs seem to be a little more expensive on the web.
    2012 Cervelo RS
    just remember...if you want to try tubless, you absolutely have to have tubeless tires. do not try tubeless w/ regular clincher tires.
    FMF 24" cruiser
    '05 Suzuki DRZ400SM
    Apr 2012
    I put 75 miles on them today and WOW, Im sure there is a big placebo effect but they really spin up fast. I could not be happier with these wheels and the GP4000s tires.
    2012 Cervelo RS
    Aug 2010
    deleted
    Mar 2007
    Quote Originally Posted by whoiswes View Post
    I don't think this is entirely accurate, at least not for every tubeless-compatible wheelset. I have a set of Ultegra 6700's and the docs clearly indicate that either clinchers or tubeless tires can be used.
    Obviously, you need a tube with a clincher, but there is zero reason why they shouldn't (and don't) work.
    You missed the point. The point was that to run tubeless you have to use a tubeless specific tire. You cant run WITHOUT tubes with a normal clincher. Obviously you can use a standard clincher WITH a tube on these rims.
    Aug 2010
    deleted
    i said "if you want to try TUBELESS you have to have tubeless tires". when the word 'tubeless' is used alone it refers to a tire without a tube, unless it is qualified further by adding 'wheels'. i said nothing about regular clinchers/tubes which will obviously work.
    FMF 24" cruiser
    '05 Suzuki DRZ400SM
    Aug 2010
    Jesus, I was just clarifying since I read it differently. I am so terribly sorry to have misread your poorly worded post.
    Reputation: bayAreaDude's Avatar
    Apr 2012
    Make sure if you try tubeless you use a sealant without amonia such as Caffelatex, otherwise those rims do corrode.
    Sometimes you eat the bar, and sometimes, well, he eats you.
    Reputation: xjbaylor's Avatar
    Dec 2006
    Sorry man, but his last post wasn't out of line, nor was his earlier post "poorly worded". Probably best just to move on.
    wow, if my post was that traumatic of an experience for you, i'm not sure what to say.
    FMF 24" cruiser
    '05 Suzuki DRZ400SM
    Apr 2012
    it is confusing. I read hundreds of pages of info and had tubular vs clincher figured out...then found out I bought wheels that are TUBEless...
    Now lets all hug
    2012 Cervelo RS
