Results 1 to 4 of 4
    Oct 2003
    Question Disc Wheelsets Slightly Different?
    As far as I know both wheelsets I have are 135mm hubs but I did buy one set used. The used set is set up with Novatech hubs and tubeless rims with dirt tires for cross/gravel and came off a cross bike. The other set is the original carbon with White Indistries hubs that I want to use it for road riding with smooth tires as a town and backup bike.
    So the first time swapping the rear from cross to road wheels I noticed the disc rotor didnít really fit into the caliper without losening and realigning the caliper. This is not a huge issue but not ideal. Any reason the wheel doesnít just swap out easily without adjustments? Also the front works without any adjustments.
    Thanks!
    Reputation: Srode's Avatar
    Aug 2012
    needing to adjust a caliper to swap wheels to prevent drag is not abnormal, but having to do it to get a wheel to fit seems odd.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    A wheelist
    Reputation: Mike T.'s Avatar
    Shim the disc. It's very normal.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with motivation, information and resources.
    Oct 2003
    OK good to know. Iím also running a blasphemous Campy/Shimano/Sram 10 speed combo so I can get a 32 rear for the dirt, which has worked well enough for this bike, but the Stam long cage doesnít exactly allow the wheel to slip in like before.
    So I guess some fiddling and then training the brakes and DR is to be expected.
    Thanks
  1. Another tire/wheelset thread... slightly different
    By krisdrum in forum Cyclocross
    Last Post: 06-30-2010, 03:35 PM
  2. A Slightly Different Hydration Question
    By MisterC in forum Racing, Training, Nutrition, Triathlons
    Last Post: 08-06-2009, 03:11 PM
  3. Another, but slightly different saddle thread.
    By EMB145 Driver in forum General Cycling Discussion
    Last Post: 12-14-2008, 03:41 PM
  4. Replies: 0
    Last Post: 07-05-2007, 08:08 AM
  5. Campy wheelsets... Different wheels, same rims but different hubs?
    By MerckxTeamSC in forum Wheels and Tires
    Last Post: 02-15-2005, 09:02 PM
