Results 1 to 8 of 8
    Jul 2013
    Does tire width affect wheel diameter? More....
    I have wheels that are ‘intended’ for 25mm tires.
    The manufacturer, with whom I communicate, advocated putting 23mm tires on them. So I did.
    Maybe I’m just imagining it, but it seems to me that the total circumference of the wheel (with the tire on it) is less than that of a 23mm wheel fitted with a 23mm tire. Specifically, there is less tire height protruding beyond the edge of the rim. Mathematically, this is to be expected, as the tire is more stretched out width-wise at the expense of height.
    But I’m wondering: is this a known/commonplace observation when fitting narrower tires to wider rims.... even when the sizing discrepancy is just 2mm?
    .je
    .je is online now
    Lizard Person
    Aug 2012
    There's a thread like yours here: 23mm on 25mm rims
    Without tires and wheels to measure, here is a helpful image:
    Reputation: Lombard's Avatar
    May 2014
    I'm thinking you worded this question backwards, but I get what you're asking.
    The diagram .je posted explains it well. Think of it this way. Take a sheet of paper and roll it into a tube. Now open that tube so the ends are further apart. Notice that the tube diameter becomes larger overall!
    Absolutely no reason to put narrower tires on those rims unless the 25mm tires will no longer fit because the clearances are too narrow. In that case, you will have to use 23mm tires.
    Feb 2002
    Quote Originally Posted by Waspinator View Post
    First of all, declaring that a given wheel is "intended" for 23 or 25 mm tires is a bit of a joke. People use a wide range of tire sizes on any given rim and 2mm difference is pretty insignificant. The only thing for certain is that wider rims will result in a wider measurement once the tire is mounted. Whether the tire is taller or not will depend on the specific tire/rim combination.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    I can think of one...
    After switching to 25mm rims, I have an inventory of 23mm tires to use up.
    May 2014
    You will just have to sell them on eBay to somebody who didn't read this thread.
    tlg
    tlg is online now
    May 2011
    Ha! I got them so cheap, I'd have to do that at a loss. I'm too friggin cheap for that.
    May 2014
    If that's the case and it were me, I would just give them away. Life is too short to ride tires just to use them up.
  1. Does wheel depth affect hill climbing?
    By jiajilah in forum Wheels and Tires
    Last Post: 08-28-2014, 09:04 AM
  2. Rim Outer Diameter Vs Tire Inner Diameter
    By mountainandroad in forum Wheels and Tires
    Last Post: 12-31-2010, 06:46 PM
  3. road bike handlebar diameter vs. road bike diameter
    By kenn in forum Components, Wrenching
    Last Post: 07-22-2009, 04:48 PM
  4. rim width affect on tubulars
    By lithuania in forum Cyclocross
    Last Post: 09-23-2008, 08:07 AM
  5. Newbie Question: Tire Width vs. Rim width???
    By scotthunt1 in forum Cyclocross
    Last Post: 09-04-2005, 11:08 PM
