Results 1 to 2 of 2
    AMP
    AMP is offline
    Jan 2002
    DT Aero Speed spokes (vs. 14/15 DB)
    Hi All,
    I'm getting ready to have a nice hand-built set of wheels built up and am looking for a little spoke wisdom.
    Here's what I know:
    Rims: Velocity Fusion (between the aerohead and the Deep V)
    Hubs: King 32H
    I'm trying to decide between DT Aero Speed spokes and DT 14/15 DB spokes. I would prefer to go with the aero spokes, but have been told that they may yield a much weaker wheel. Given that the rims are pretty beefy should I be concerned that the Aero spokes will significantly weaken the wheel?
    For reference I'm at about 230 and dropping. I spin much more than I mash and I'm very careful about avoiding obstacles. I would like something that spins up relatively fast.
    Also, I have a pair of open pros laced to 32H Record hubs with 14/15 DB spokes. I've got over 5000 miles on them and they have never needed truing. I finally took them in to be looked at over a month ago and they came out needing very little adjustment. They needed a slight tension adjustment and that was all.
    Thanks!!
    Reputation: Nessism's Avatar
    Quote Originally Posted by AMP
    Hi All,
    Here's what I know:
    Hubs: King 32H
    Thanks!!
    King hubs use an aluminum freehub body which allows the cogs to dig in and damage the splines. For this reason Shimano uses a Ti freehub body on their high end 9 speed hubs (which work with 10 speed as well).
    Regarding the spokes, they are a little on the light side (similar to 15/16's), you might want to consider something stronger, at least for the drive side rear.
    Good luck.
    Ed
  1. Wheels and tires
    By francois in forum Wheels and Tires
    Last Post: 07-16-2005, 08:22 PM
  2. 9/10 speed wheelset to 8 speed?
    By longhorn31 in forum Campagnolo
    Last Post: 01-11-2005, 02:43 AM
  3. Wheel Durability, Spoke Count & Guage.
    By czardonic in forum Components, Wrenching
    Last Post: 12-31-2004, 08:22 PM
  4. what if i want 8sp?
    By colker1 in forum Components, Wrenching
    Last Post: 06-05-2004, 04:22 PM
  5. Athena RD 8pd
    By rfrancisco in forum Campagnolo
    Last Post: 04-08-2004, 07:36 AM
