Results 1 to 6 of 6
    Oct 2009
    DT Swiss 240s Road Hub Maintenance
    I have 240s front and rear road hubs. The, manual indicates to service the hubs yearly. However, depending on the rider, this could mean 1000 miles or 10000+ miles. Is there a rough mileage guide for servicing these hubs? Also, it does not appear that the front hub can be serviced other then replacing the bearings. Am I missing something else that should be serviced?
    A wheelist
    Reputation: Mike T.'s Avatar
    You can clean & re-lube the drive ratchets and replace the bearings. The re-lube should be done when the hubs get more noisy. That's a no-tool quick operation. The bearings won't need service until they are worn out. They list a special tool kit for hub overhaul. I never did this on mine but I'll bet the bearings can be replaced without it - all except the one behind the ring drive, for which the special tool will be needed to remove the ring drive.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilder's with motivation, information and resources.
    Everything above, up to that blue line, is IMO IMO.
    Reputation: jmess's Avatar
    Aug 2006
    One of my ratchet rings started to stick in the free hub body at around 9K = 3 years. I think I will service them a little sooner next time; 3K is probably about right. If you do a lot of really wet rides you may want to service them twice as often. I noticed they were getting pretty loud at around 6K.
    Oct 2009
    Thanks for the info guys.
    I know this is an old thread, but can anybody tell me how to disassemble the front hub? I cannot find images or videos and you cannot do it with allen keys. Am I missing something? Thanks!
    'brifter' is a lame word.
    axle vise, they pull right out. bearings are installed/removed like any cartridge bearing. basically the same as the rear hub.
    I work for some bike racers
    and a bunch of skateboards
  1. DT Swiss 240s hub shell
    By WOY in forum Wheels and Tires
    Last Post: 02-08-2009, 02:33 PM
  2. Anybody service a DT Swiss 240s hub themselves?
    By unknownrash in forum Components, Wrenching
    Last Post: 10-09-2007, 06:29 PM
  3. DT swiss 240s vs DA
    By battaglin in forum Components, Wrenching
    Last Post: 02-24-2006, 07:37 AM
  4. DT Swiss 240s
    By Koop in forum Wheels and Tires
    Last Post: 01-29-2006, 04:26 AM
  5. DT-Swiss 240s hubs
    By Mordi in forum Hot Deals
    Last Post: 11-17-2005, 02:04 PM
VISIT US AT and the ConsumerReview Network are business units of Invenda Corporation
