Results 1 to 25 of 36
    Old and in the way.
    Aug 2014
    DT Swiss, Easton, or Fulcrum?
    Looking for a second set of alloy wheels, and wondering if any of the more experienced members here have a brand preference between those three brands. I'm a road rider and will be mounting (likely) some 700 x 25 Contis. Club riding, no racing.
    Reputation: Lombard's Avatar
    May 2014
    All these are respectable brands. May I ask why you want a second set of wheels and what do you want to achieve that you don't have in your existing wheel set?
    changingleaf
    Aug 2009
    From my experience the DT Swiss hubs are the most reliable.
    Old and in the way.
    Aug 2014
    Mostly convenience to run a second, and different set of tires. I switch between Conti GP 4000s and Conti GP 4 Season tires frequently depending on the ride. If I can get an upgraded and lighter set that would be a bonus.
    Just an anecdote but the number of complaints and problems I've seen people I ride with or have heard about with Easton wheels would be enough to put me totally off the brand for wheels. Broken spokes and not staying true has been the problem I hear about and see which I assume comes from poor build quality/lack of QC.
    Old and in the way.
    Aug 2014
    May be anecdotal, but still worth hearing. My ride came with DT Swiss, and the rear wheel needed a few spoke replacements during the first year of riding. It's been good since then, but I didn't expect that.
    wut?
    Reputation: Clipped_in's Avatar
    May 2011
    OP have you considered the HED Belgium+ ? It's really a great rim!
    There I was...
    Aug 2004
    You might want to consider hand-built wheels. Cost is about the same and build quality is often much more consistent. I have had a few wheels built by Ergott and November Bicycles. It can be customized to your weight and you can choose colored hubs (Chris King, Industry 9 and White Industries) and nipples to add some bling.
    Fulcrum, which is actually Campagnolo, are excellent factory wheels. I’ve had Shamals and Racing Zero for years with lots of mileage. Campy makes some of the best hubs in the industry - they spin forever.
    Sent from my iPad using Tapatalk
    My Bikes
    "It's supposed to be hard...The hard is what makes it great."
    'brifter' is a lame word.
    Quote Originally Posted by veloduffer View Post
    The only issue is they're totally proprietary. And spinning forever means nothing in the real world.
    I work for some bike racers
    and a bunch of skateboards
    Nov 2015
    On the other hand, I've run Easton wheels for the past 7 or 8 years and thousands of miles on and off-road, and I've only had one issue (that was probably due to negligence - cracked rim from possibly overtightened spokes on a rear EA90 XC). People have bad luck with all sorts of brands. But now that expensive Eastons don't go on regular massive closeouts at Nashbar, I'd shop other brands (or go to eBay or Pinkbike for a lightly-used wheelset).
    Anyway, I currently have a set of EA70 SLs and EA90 SL/SLXs (and Havens and Heists), and they're all great, strong wheels. DT looks to make some nice wheelsets as well. You can often find take-off Rovals with 240 or 350 hubs for 50% off on eBay.
    Old and in the way.
    Aug 2014
    Quote Originally Posted by Clipped_in View Post
    I looked at the HED Ardennes, but they limit your tire pressure to 90psi. I frequently ride at higher pressures, so they're a no-go for me.
    Reputation: Wetworks's Avatar
    Aug 2012
    Fulcrum... Racing Zero...they spin forever.
    Yes, I recently put them on my Allez Sprint, they're delightful.
    Old and in the way.
    Aug 2014
    I saw a pair of 4db wheels on line for about $350. Seems like a steal. Would you?
    Old and in the way.
    Aug 2014
    Fulcrums Proprietary?
    If they're proprietary, does that mean my LBS can't work on them?
    Aug 2004
    Quote Originally Posted by dmanthree View Post
    Maybe. Nowadays, many shops send the back to the factory, in part to not void the warranty and some shops don’t have experienced wheel builders.
    My Bikes
    Aug 2004
    True. But Campy wheels have a long history of solid, reliable wheels but they are in the middle of the pack on the weight side.
    My Bikes
    Aug 2004
    What’s 4db?
    My Bikes
    Apr 2015
    Competitive Cyclist is having a sale on the Easton EA 90 SL wheels. They weigh 1490 grams, 19.5 internal width and 24.5 external width. I have put 3k miles on them and I haven't had one problem. https://www.eastoncycling.com/produc...ea90-sl-wheels
    Apr 2015
    You could also get some DT rims with a Powertap hub and get a power meter for $500.
    https://www.powertap.com/product/dt-...0-alloy-wheels
    May 2014
    Quote Originally Posted by Sojodave View Post
    3K miles is not much. I would expect at the very least least 10K miles without a problem.
    I do know someone who has a pair of Fulcrums with over 21K miles. The rear brake track is now concave, but they have never had any problems otherwise. Granted that she is slight. A 200+lb. rider would probably have trashed those sooner.
    Apr 2015
    I had some Fulcrum Racing 5's, I had problems with popping spokes. I liked the Easton's better.
    Old and in the way.
    Aug 2014
    What’s 4db?
    Sorry. Fulcrum Racing 4db. Their top alloy road wheel.
    Old and in the way.
    Aug 2014
    Need disc wheels.
    Those are rim brake models, but I need disc models. I should have specified.
    May 2014
    How many miles before the Fulcrums started popping spokes? How much do you weigh? Are you a spinner or a masher?
    Apr 2015
    I had the Fulcrum about 1.5k when I started having spoke problems. I weigh 190 and I'm a spinner. I had them repaired twice. I got in a serious accident last year and the Fulcrum folded like a bad hand.
  1. DT Swiss 1800 vs. Fulcrum Racing 6 Wheels?
    By Eyost in forum Components, Wrenching
    Last Post: 03-28-2011, 12:29 PM
  2. Fulcrum racing 1 vs. Dt Swiss 240s+RR1.1 +aerolites
    By Wilier_speed in forum Wheels and Tires
    Last Post: 01-20-2009, 11:24 AM
  3. DT Swiss RR1450 vs Fulcrum Racing 3
    By Mr. Papagiorgio in forum Wheels and Tires
    Last Post: 10-16-2008, 02:12 PM
  4. Replies: 2
    Last Post: 08-13-2008, 07:14 PM
  5. DT Swiss VS. DT Swiss
    By Phat&SlowVelo in forum Wheels and Tires
    Last Post: 12-29-2005, 09:12 PM
