Results 1 to 9 of 9
Thread: EA90 SLX Flex
    Sep 2011
    EA90 SLX Flex
    I got a new set of Easton EA90 SLX from a friend recently, these are not he Performance Bike wheels, these are the ones that retail for $1050.00 with the ceramic bearings. I had a chance to ride them over the weekend and I was suprised how much flex these wheels had. The front would rub the brakes as soon as I got out of the saddle and not even pushing it. They flex more than any other wheel I have owned. I contacted Easton and there great advice was open up my brakes. You must be kidding me.....
    I am 190 lbs and think considering the price point of these wheels they should be a lot stiffer. I will say they do climb and spin up real fast.
    Anyone else see similar results. I wonder if the spoke could be retensioned to stiffen them up?
    Sep 2011
    FWIW - I'm 5'9'.5'' / 150 and they work great for me. They are wider than the cheap shimano r500 wheels that came on my bike and required opening up the brake a little but that was due to the rim width, not flex.
    Feb 2007
    Slightly off topic, but I've got my EC90s on my bike at the moment. They flex a little more than my 32 spoke triple laced trainers, but opening up the calipers has fixed that. I'd echo mcr23 that Easton's rims seem to be pretty wide compared to others. I'm 5'9 and 185 pounds, and Seattle has some serious steep hills you need to stand up and stomp, and I don't get any brake rub.
    Jul 2008
    Quote Originally Posted by mwags View Post
    Simply put, I think you are too heavy for the SLX wheels. You would be better suited for the EA90SL wheels. I am 200# and have no issues with flex in the SLs.
    Oct 2008
    Its an 18/24 spoke wheel, you need something more substantial. Retensioning wont help!
    cmg
    cmg is offline
    Reputation: cmg's Avatar
    Oct 2004
    need a higher spoke count wheels. a light rim with a higher spoke would better. Try looking at Bicycle wheel warehouse Road - 700C - Riders 220 or less - Pure Race SuperLight 700c - Bicycle Wheel Warehouse
    Aug 2010
    I have some EA 90 TTs. I am 160 lbs (5'6") and I can also feel a fair amount of flex in them. Some in out of saddle sprints but a lot more when I push it up a climb. I recently got some Reynolds DV3Ks and I could feel on the first test ride that they are a lot stiffer. Absolutely no flex in a sprint.
    Reputation: emartin's Avatar
    Mar 2009
    You cannot have the best of both world...at your weight, a lightweight shallow aluminum wheelset with low spokes count will flex. I'm very fit and muscular racer at 172 lbs and I can flex alot of wheels.
    Now, my shallow/light wheels are Shimano Dura-Ace C24 and (except my rim oxidation problem) they are the stiffest lightweight wheels I tried.
    BTW I saw alot of racer changing there Easton wheels during races because of a broke spoke...
    2011 Giant TCR ADV SL1
    2011 PedalForce TT2
    2010 Giant 72 Bowery
    2012 Giant Anthem
    Homemade Bamboo winter bike
    Aug 2006
    A fellow rider also had a set of these, and his flexed a lot too. He only weight about 155.
    You can get away with low spoke counts on deep rims, but not such a great idea on a shallow aluminum rim.
Sea Otter Classic
Contest
