Results 1 to 6 of 6
    Dec 2009
    Easton R90 SL ERD
    Does anybody know the true ERD for Easton R90 SL? Would like to order spokes with rims
    Dec 2011
    582 is our place holder ERC, but it's best to measure yourself. Their stated 580 ERD is measured in a funky way that doesn't include nipple heads and seems wrong anyhow.
    Dec 2009
    Quote Originally Posted by November Dave View Post
    Is ERC the same as ERD? I wonder why there is so much difference in ERD between Pacenti SL23 (589 ERD) and Easton R90 SL? There is only 1 mm difference in rim depth. I was hoping I might able to reuse my spokes but I think they will be too long.
    Dec 2011
    ERC is the fat fingers typing on an iPad version of ERD.
    Your spokes will be too long. For example and from memory, a set of SL23s laced 24/28 radial front and 2x/2x rear with WI T11 hubs is 277mm front, 282 non-drive, and 277 drive. A set of R90SLs with same hubs and lacing is 274.5mm front, 280/275 rear. We use a spoke cutter/threader so our spoke sizes are in .5mm increments. This is not broadly necessary.
    Part of the ERD difference is that the Easton has a thicker spoke bed. They don't crack.
    Dec 2009
    Dave,
    That is what I thought. I am going to order the rims and measure the ERD myself.
    What spoke tension do you recommend on the drive side for the Easton rims?
    Dec 2011
    We try to get at least 55 on the non-drive side. Some hubs need more drive side tension than others to do that. 125 should get you there with most good hubs.
  1. Easton EC90SL tubular ERD?
    By quickfeet18 in forum Easton
    Last Post: 02-04-2010, 03:30 PM
  2. where to find ERD
    By Steel_4_the_feel in forum Wheels and Tires
    Last Post: 05-23-2005, 07:24 AM
  3. Ambrosio Excellite Rim ERD?
    By Ken in forum Components, Wrenching
    Last Post: 05-22-2005, 03:37 PM
  4. ERD helium rim
    By the bull in forum Components, Wrenching
    Last Post: 11-22-2004, 05:40 AM
  5. ERD of 700c Open Pro rim?
    By DougSloan in forum Components, Wrenching
    Last Post: 02-13-2004, 08:46 AM
