Results 1 to 10 of 10
    Nov 2002
    Enve 4.5 vs ROVAL 64 CLX.
    Has anyone done a comparison?
    2016 Orbea Orca OMR w/Dura-Ace 9070 Di2, Zipp Aero SL70, Enve stem, Vision Tri-Max 35's, S-Works Carbon Power saddle, FSA Force SB32 seatpost, Sram XG1090 cassette, Look Keo Blade Ti's.
    15.9lbs
    2013 Wilier Zero. 7 w/e-Tap, Zipp Aero SL70, Enve stem, S-Works carbon Power saddle, Red cranks w/Rotor "Quarbon"/Roval 50's, Ritchey Superlogic post, Look Keo Blade Ti's, Rotor Uno cassette, Red 22 brakes. 14.08lbs.
    2016 Cervelo Rca, THM Clavicula cranks, AX Lightness stem, bar and seatpost.
    Feb 2012
    Quote Originally Posted by tabl10s View Post
    You should get the Enve because they have revolutionized the wheel industry by making the front wheel shorter than the rear and the incredible breakthrough internal spoke nipple design....
    Said no one ever....
    changingleaf
    Aug 2009
    The Roval is tubeless ready, which is nice if you want to run tubeless, but tires are harder to mount and unmount.
    Tires are easier to mount on the Enve 4.5 rims and you can choose any hub you want with a custom build, but it's not tubeless ready.
    Feb 2002
    Quote Originally Posted by Keoki View Post
    Please explain what a "shorter" wheel is.
    Reputation: Srode's Avatar
    Aug 2012
    he means shallower front wheel depth than back.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Jun 2015
    Ignore him. He's basically a troll with an unreasonable hatred of ENVE.
    Sep 2011
    forget both, go for the Easton EC90 Aero 55 (if your frame can fit them). The Easton is incredibly stable in crosswind compared to ANY wheel that is 50mm or deeper AND the Easton are very fast AND tubeless ready AND it's cheaper. Only problem is that the Easton are wide (28.5mm at the brake track and a tad wider at the middle of the body) and some frames will not fit them.
    Feb 2012
    Quote Originally Posted by ceugene View Post
    Simon Smart, man. Freaking genius!
    Reputation: spdntrxi's Avatar
    Jul 2013
    Drag2Zero and Endura... what do you got?
    Feb 2012
    Quote Originally Posted by spdntrxi View Post
    Got nothing on me, but he's got you to buy into his gimmick. LOL!
  1. Replies: 0
    Last Post: 11-22-2016, 07:55 PM
  2. Roval Rapide CLX 40: damaged breaking surface?
    By jackbauer1909 in forum Specialized
    Last Post: 04-01-2016, 09:20 AM
  3. 2013 Roval Rapide CLX 40 actual user thoughts
    By jefferson68 in forum Specialized
    Last Post: 03-21-2015, 05:29 PM
  4. 2013 Roval Rapide CLX 40 actual user thoughts
    By jefferson68 in forum Wheels and Tires
    Last Post: 05-05-2013, 10:21 PM
  5. Specialized Roval Rapide CLX 60
    By hd tech in forum Wheels and Tires
    Last Post: 03-04-2013, 02:34 AM
