Results 1 to 21 of 21
    Journeyman Wheelsmith
    Feb 2011
    Errant nipple stuck inside wheel -- I've tried everything
    I've never had this problem before. I built up a Pacenti SL23 wheel awhile back and while I was building it, I dropped a nipple inside. No biggie...I'll fish it out when I'm done. Forgot out about it and now I periodically hear it bouncing around when I first take off.
    Remove the wheel, rim tape, have spun it fast/slow, shook it every possible way I can think off...errant nipple won't come out.
    Ideas?
    Thanks,
    Bob
    .je
    .je is offline
    Lizard Person
    Aug 2012
    More patience.
    That's how I did it.
    I have a hard rubber mat over some concrete. I usually just sit there gently bang it on while holding wheel upright. It eventually bounces out .
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    vacuum pointed at valve or spoke hole at 6 oclock. A little shaking like that and even the worst make their way out.
    Boyd Cycling owner
    Reputation: coachboyd's Avatar
    Jan 2008
    You can also use the bend of a j bend spoke. I always use a 216mm, but that's only because it's the top left spoke in our spoke shelf (so I never misplace it).
    www.boydcycling.com Handcrafted Revolution
    'brifter' is a lame word.
    Quote Originally Posted by Enoch562 View Post
    This is exactly what I do...works every time.
    I work for some bike racers
    and a bunch of skateboards
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Is the nipple magnetic?
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by jetdog9 View Post
    Aluminum, brass? What else is there (that normal people use)?
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with motivation, information and resources.
    A wheelist
    Patience Grasshopper. Everyone who has built more than a couple of wheels has probably done it. And we all survived - and won. The feeling of accomplishment when it happens is almost worth the problem.
    changingleaf
    Aug 2009
    Like some others have said, dribble the wheel on a hard mat or carpet with the valve hole on the bottom. It usually comes out pretty quickly.
    Dribble by letting the wheel drop about an inch, let it bounce a couple times and repeat.
    Feb 2003
    Thanks for the tip, I've always just shaken the rim to get the nipple to the 6:00 position and fished it out with a small pick. Vacuum should do the trick.
    Feb 2006
    I never tried the bouncing or vacuum methods, either should work.
    What I did:
    A flat screwdriver with a dab of caulk on the blade.
    With the valve hole on the bottom side, insert the screwdriver from the hub side of the valve hole so that the caulk is near the bottom, then shake the rim a little to get the nipple to stick to the caulk.
    Russian Troll Farmer
    Sep 2016
    You've obviously never built a wheel.
    "L'enfer, c'est les autres"
    Feb 2002
    Steel nipples? That would be a new one.
    Feb 2011
    Ok, none of the above methods worked. It's not a stray nipple. It's the rim pin/joint that is moving and bouncing off one of the nipples.
    I should have found this sooner, but in my defense I have 0% hearing in left ear so directional sound is a challenge.
    What's the best method to secure the pin? I see previous punch marks in the rim bed but I'm a bit leery to do that to my nice round and true wheel.
    Bob
    Attached Thumbnails Attached Thumbnails Errant nipple stuck inside wheel -- I've tried everything-img_0856.jpg
    Hit it w/ a punch again. Shouldn't knock it out of true, if it does you know how to fix it.
    Huge in Japan
    Reputation: craiger_ny's Avatar
    Jun 2014
    I don't think that is a pinned joint but rather a sleeved one. I have hit them with a punch to quiet them down but I have also, at the suggestion of others here, used Gorilla Glue to quiet them with success. Drip some water in and slosh it around the sleeve then add Gorilla Glue. It has worked for me.
    Interwebs bumpersticker goes here
    A wheelist
    Quote Originally Posted by craiger_ny View Post
    The rim is a sleeved joint with the sleeve staked (hence the punch marks) in place. Pacentis were famous for the plug rattling. My rear SL23 vII rattles. Most sleeved and staked rims have sealing goop around the plug, applied at the factory.
    It's possible to re-stake the rim (support the rim in the edge of a 2x4!) and/or dribble glue of choice through a rim bed nipple hole and let it run into the joint.
    changingleaf
    Aug 2009
    That looks like a welded rim. There is a heat-sink inside the rim at the seam area and sometimes it comes loose. You can see that it was peened into place at the seam. Just put some glue or loctite in the nearest spoke hole and let it drain next to the piece of metal. It will fill the gap and solve the problem.
    Feb 2006
    Yes, Gorilla Glue expands and cures using water. Did you put the glue in via the nearest spoke hole? Or through the joint itself? Aren't the pins inside the extrusion, so glue through the spoke hole won't reach them?
    Gorilla Glue expands a lot. Experiment on a piece of cardboard to see the expansion volume.
    Huge in Japan
    Jun 2014
    Quote Originally Posted by rm -rf View Post
    I put it through the adjacent spoke holes then rotated the rim in all directions so that I was satisfied that it was distributed. If it were pins then you are correct that there is some likelihood that it will not get where you need it. By all appearances this is a sleeve which is a reverse image of the inside geometry of the rim extrusion which is accessible to the glue.
  1. Shifting is less than ideal, tried everything
    By thisisthebeave in forum Components, Wrenching
    Last Post: 10-02-2015, 10:13 AM
  2. Brake pads rubbing, feel like I've tried everything
    By jfd986 in forum Beginner's Corner
    Last Post: 03-20-2014, 12:26 PM
  3. I have not found a solution to this cold - but tried everything
    By onespeed in forum General Cycling Discussion
    Last Post: 02-16-2014, 07:44 AM
  4. Would you do 14mm nipple here? (pic inside)
    By adam_mac84 in forum Wheels and Tires
    Last Post: 03-10-2013, 10:44 AM
  5. Cyclist chews out errant driver
    By oldskoolboarder in forum Commuting, Touring and Ride Reports
    Last Post: 04-11-2005, 12:35 PM
