Results 1 to 15 of 15
    a real member's member
    Jul 2016
    first gravel ride with panaracer tires
    i'm thinking about doing a two-day gravel ride, but i have no tires. all my road bikes have 23mm tires. i can probably only go as wide as 28mm on my sun m13ii rims. i think i'll buy panaracer gravelkings. they come in 26mm and 28mm. should this choice be any kind of dilemma? or do i simply buy the 28s? i'm a little uncertain at this point about the gravel conditions. thanks.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    First thing to do is find out what kind of surface you're riding over. Rails/trails that is dry a 28mm would work for....but pea-gravel, you won't even be able to ride out of a parking lot with 28mm.
    Feb 2002
    No, the first thing to do is figure out what will fit in the frame. When somebody says "i can probably only go as wide as 28mm" then I kind of wonder whether they actually know what will fit.
    Jan 2005
    If the surface is peanut butter or pea gravel....having a ≤28mm clearance disqualifies you no matter what the exact number is. You're not even going to get out of the parking lot.
    Jul 2016
    gotcha.
    not worried about the tire fit in the frame/calipers in the least, but tire fit on the rim.
    internet says 32mm will work, but 28mm seems more reasonable on these.
    Reputation: Srode's Avatar
    Aug 2012
    Are your rims the limiting factor for tire size or your frame? You can put a fairly wide tire on narrow rims you know. i have a set of rims for a cross bike that have 18 outer rim width and 14mm inner- the bike came with 32mm tires.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Jul 2016
    dunno why wide tires on these scare me so much. may be a phobia or ocd.
    Oct 2017
    I have ridden most of the popular gravel roads and trails in the area (Olympics, Cascade Foothills, etc...). I might be able to give you some idea of what to expect if you let me know where.
    I can't think of a lot trails that will accommodate 28's except for the rail trails (basically Snoqualmie Valley Trail and the John Wayne Pioneer Trail up to Hyak and through the tunnel). Anything easy of Hyak, the gravel gets bigger, deeper and looser, and 28's are going to be a challenge.
    I presume you are bringing tubed wheels and tires? If so, you'll want to bring lots of spares.
    'brifter' is a lame word.
    Quote Originally Posted by blackfrancois View Post
    You do know that people have raced CX on narrow clinchers for decades, right? And don't forget how narrow mtb rims were for years and years. It's not a problem.
    I work for some bike racers
    and a bunch of skateboards
    And you thought strangers on the internet who have no idea where you live would be?
    Seriously dude, I have absolutely not clue what will fit your frame, how much you weigh, how much help you could use bike handling wise from going bigger or the conditions of the road.
    Personally I use anywhere from 25mm (my regular road tires) up to 40 depending on conditions.
    Reputation: Lombard's Avatar
    May 2014
    There is a difference between what you "could get away with" and what would be optimal. You may get away with 28mm tires, but it may be either a white knuckle experience or just a very slow ride.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    If you are worried about width alone on a standard width 700c rim, I wouldn't worry about 28s. Like cxwrench notes, I've raced cross on 28's using regular road clincher wheels. I used 27 mm Panaracer EVO Race gravel tires on Mavic MA40's for Cali Eroica and they were nice, but just measured out to 25 mm wide though. I've never subscribed to the maxim you need really wide tires to ride on gravel, and use 23's on mixed paved/gravel all the time.
    Jun 2017
    As the first poster said, it really depends on the gravel surface. I've ridden gravel where my road bike and 25's work fine, and ridden some where my 38's were sinking in and making the ride miserable.
    Russian Troll Farmer
    Sep 2016
    On crushed stone and 'fire road' gravel, 28's should be OK. Around where I live, there are a lot of rail trails where the surface is simply old New York Central Railroad ballast (from the period AFTER cinders made it smoother), and on those trails, I'm damn glad I have 42's!
    "L'enfer, c'est les autres"
    Reputation: velodog's Avatar
    Sep 2007
    Put the largest tires that'll fit the frame, fork and brake calipers and don't worry about how they fit the rims. The more supple the tire, the less they will be bothered by narrow rims. People been putting wide tires on narrow rims since before I was a gleam in my fathers eye and it all worked out fine.
    It hasn't been a problem till the last few years.
    Too old to ride plastic
  1. Replies: 2
    Last Post: 07-13-2016, 04:42 AM
  2. Tires (?) Panaracer Kevlar Liners
    By thevalvesource in forum Cyclocross
    Last Post: 03-08-2009, 05:57 AM
  3. Panaracer Cross Blaster Tires
    By Mountain Goat in forum Cyclocross
    Last Post: 10-25-2008, 09:57 PM
  4. Doh moment ... Panaracer Pasela tires
    By tarwheel2 in forum Commuting, Touring and Ride Reports
    Last Post: 08-20-2007, 10:54 AM
  5. Thoughts on Panaracer Tires
    By davidh in forum Cyclocross
    Last Post: 10-20-2005, 11:18 AM
