Results 1 to 21 of 21
    Apr 2002
    Folding Bead vs Rigid Bead
    I am thinking of buying Schwalbe Durano Plus tire - SmartGuard. It has a reputation for being very difficult to install. I was wondering, whether the folding bead or the rigid bead tire would be easier to install.
    Dec 2006
    The "rigid" or wire bead tire is usually easier to mount than a Kevlar, or folding bead.
    a real member's member
    Jul 2016
    agree with peter.
    steel beaded tires are usually less expensive than their kevlar counterparts, and they're easier to install. i see little downside.
    tire jacks are pretty inexpensive ($15), so having one at home for stubborn tire/rim combos isn't a big deal. but getting stuck out on the road without one if that combo flats might be.
    Apr 2011
    Quote Originally Posted by blackfrancois View Post
    But I imagine there is plenty of room for a TJ in the bag... Name:  Emoticon-Think.gif
    Oct 2013
    I have 3 tire levers in my bag, and use all of them, usually. No problem.
    BANNED
    Reputation: Lombard's Avatar
    May 2014
    Tire levers are great for removing the old tube, but not a great idea for mounting as you can pinch the new tube with them.
    Yes, wire bead tires are generally easier to mount, though wire bead tires generally have more rigid sidewalls and will give you a harsher ride.
    As far as the "tubeless rims are hard to mount" argument (and most new rims now are tubeless compatible), yes, they are harder, but there is a technique. After lots of cursing, once I learned the technique, it's no longer a big deal.
    The key is to work your way from the opposite end of the valve. Shove the tire bead inside the grove at that end and work your way with each hand around the tire until you get to the valve end. Be sure to continue squeezing the tire beads into the middle where the grove is. Snap, done! Curse words - zero!
    Oct 2013
    I do it all the time, no problem. You just have to pay attention, don't listen to the bystanders lauf'ing at the clown.
    BANNED
    'brifter' is a lame word.
    I always recommend leaving the levers out of the install part. The majority of people are barely capable of getting a tire on a rim much less being careful enough to not damage the tube.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2002
    I have found this tool to be very helpful. Also, easy to take along.
    https://www.sjscycles.co.uk/tools/va...evers/?geoc=US
    Jul 2016
    Quote Originally Posted by daniell View Post
    i bought one of those var tools on ebay once when i had a set of ambrosio extra elite rims. those rims are notorious for mounting tires. and that french tool worked pretty well.
    i sold the tool on craigs for what i paid for it after i rid the wheelset.
    i recently came across the same model wheelset on a friend's bike i was overhauling. the tires were mounted backwards, which was really bugging me. i debated with myself if i should try to remove them and fix the problem. i finally did, just using two park plastic levers. it was really hard, though.
    Reputation: velodog's Avatar
    Sep 2007
    Yep, handy little tool.
    Too old to ride plastic
    Sep 2007
    When I was a kid I remember figuring out how to use a screwdriver for a lever.
    Good thing those kids bikes had steel rims, other wise there would have been more than damaged tubes to worry about.
    Feb 2002
    Were these MTB or CX tires, because with road tires, there really is no "backwards" despite the fact that there might be an arrow molded into the sidewall.
    pmf
    pmf is online now
    I used screw drivers when I was a kid too.
    These are awesome
    https://www.parktool.com/product/tire-lever-set-tl-4-2
    Let me guess. You googled some reviews and a lot of people had trouble mounting it?
    That would be true of any tire but especially 'recreational' tires such as that because it's users tend to have less experience.
    I doubt it should be a concern and if you have problems with that one you probably would with any. Just get which ever you want to get.
    May 2014
    I've wondered about the arrow on road tires as there is no forward or backward tread pattern. I guess just a marketing tool to make the end user think they are getting some extra performance by a specific mounting direction.
    Apr 2002
    Numerous reviews complain how difficult installation is. It was obvious to me that many were experienced riders.
    Sep 2007
    Using the directional arrows will keep the tire labeling on the same side. But it's probably easier to find the label than the arrow.
    Jul 2016
    the label was not centered over the stem and it was on the nds -- i.e. "backwards."
    and i always mount the arrow going the correct way, regardless of the difference it would make.
    Feb 2002
    Maybe, but more likely it is there to prevent a lot of inquiries from people who want to know which way to mount the tires, even though it makes no difference which way you mount the tires.
    May 2014
    Good point.
  1. folding tire vs non folding tire
    By ctkeebler in forum General Cycling Discussion
    Last Post: 05-21-2012, 03:53 AM
  2. Wire bead or folding-on the road differences?
    By Kuma601 in forum Wheels and Tires
    Last Post: 01-22-2011, 03:36 PM
  3. Folding tire vs rigid tire
    By BruceG1 in forum Wheels and Tires
    Last Post: 08-29-2010, 09:44 AM
  4. folding tires faster than wire bead?
    By lawrence in forum Wheels and Tires
    Last Post: 08-13-2007, 01:05 PM
  5. what's the diff between rigid and folding tires?
    By pdxtim in forum Wheels and Tires
    Last Post: 02-23-2007, 02:14 PM
