Results 1 to 14 of 14
    Apr 2011
    Front Hub Recommendations?
    I'm in the market for a budget oriented front hub. My requirements are 24 spokes (bladed preferred but not required), rim brake, traditional quick release skewer. Any recommendations?
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by bvber View Post
    Any of the hubs at bikehubstore.com will fit your criteria. As to your "bladed" needs, any of their hubs will accommodate "bladed" spokes like CX-Ray.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with motivation, information and resources.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Mike T. View Post
    I don't know how generic Bvber wants to go. The Bitex hubs at Bikehubstore.com are not available in 24 hole. Don't know that I'd want to chance the no-name hubs shown there.
    Too bad the Ultegra 6800 hubs aren't available in 24 hole, only 32 or 36. They are your best bang for the buck. Personally, if I had to have 24 hole, I'd spring for Dura-Ace 9000:
    https://www.amazon.com/Shimano-HB-90...YDO?th=1&psc=1
    Guest
    I built a wheel with the BHS SL79 front hubs with 20 spokes radially laced. Almost 6k miles and no problems.
    The hub axle won't allow you to use the larger diameter Ultegra skewers, that's been my only complaint. I had to use the BHS standard skewer in front (I have a T11 rear hub that takes the Ultegra skewer).
    A wheelist
    Does "Bitex" really matter? I've had lots of 24h front hubs from BHS, and I've never known the maker (ha, they get re-branded with my logo!!).
    May 2014
    Russian Roulette? How many miles have you put on these hubs?
    A wheelist
    I don't really care. BHS doesn't sell 2nd rate stuff. If bearings wore out too soon I'd replace with the finest ones I could find.
    Dec 2011
    BHS SLF85W (they are very much available in 24h) and be done. There are better front hubs out there but you will pay much more for them. We've had a few hundred of those go out on builds we've done and they are a very good budget hub and they work just fine with any skewer I've ever put in them. And I'm a big fan of robust skewers, most of mine are Ultegra.
    The nice thing about BHS is that they use full contact seal Enduro bearings in their hubs. A lot of OEM hubs, even of the same hub model, come spec'd with terrible bearings.
    May 2014
    Quote Originally Posted by November Dave View Post
    Really? I understand these are very good quality bearings. You would think BHS would give their own hubs a brand name.
    Dec 2011
    They are Bitex hubs, as clearly identified by BHS.
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    I agree these are nice hubs regardless of price. No need to be brand elitist, Bitex have a solid reputation.
    Off topic somewhere but if you want to use radial, make sure the hub is cool with that. Most are but there are exceptions.
    The SLF85 is a solid hub.I have built a bunch of them in and not 1 problem.
    May 2014
    OK, I missed that in the individual options on the right, it says Bitex. It's not in the main description. My mistake.
    F125 Front Hub
    SuperLight 79 Front Road Hub
  1. Front hub to match Powertap 2.4 rear hub
    By Srode in forum Wheels and Tires
    Last Post: 11-23-2016, 03:58 PM
  2. Replies: 3
    Last Post: 05-01-2013, 06:54 PM
  3. setting up rollers -- front roller axle vs front hub axle
    By teleguy57 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-03-2009, 06:39 PM
  4. 2007 front veloce hub vs 2005 front veloce hub
    By fah35 in forum Wheels and Tires
    Last Post: 10-21-2008, 05:18 PM
  5. making a fixie hub (from a front disc hub)
    By itsdoable in forum Fixed/Single Speed
    Last Post: 03-26-2004, 05:05 PM
