Results 1 to 9 of 9
    May 2014
    Angry Giant PSLR-1 aero failure
    Has anyone else experienced this. These PSLR-1 aero wheels have about 4000 miles on them and are three years old. This occurred a couple of weeks ago after two century rides. Giant dealers are not sure what happened. Both front and rear are cracked at the same spot. They are currently set up as tubeless. Needless to say, I am not riding on them.
    Attached Thumbnails Attached Thumbnails Giant PLSR-1 aero failure-img_1898.jpg   Giant PLSR-1 aero failure-img_1895.jpg
    Feb 2002
    Quote Originally Posted by docboss View Post
    Is that fairing structural? Does the spoke attach to the aluminum rim underneath or to the CF portion? If the spoke attaches to the aluminum rim, then this is mostly cosmetic. If the CF is structural then the wheels are pretty much toast. Caused by tightening the valve stem nut?
    May 2014
    One Giant dealer said it was not "structural", but three others said it is, as the fairing is bonded to the aluminum. That, to me, sounds like "no".
    I spoke to the Giant shop that did the conversion to tubeless about the valve stem issue. They claim there is no way they would, or even could tighten them that much. In their opinion, it was caused by the flex of the rims, cracking the bonded fairing at its weakest point, the valve stem. None of the shops would recommend riding on them.
    I am a powerful, 215 lbs. rider. These wheels, are a rebranded DT, with 16/20 spokes that may not have been the best for me, per the shop.
    The Giant rep has seen the photos. His response..."not warrantied". No explanation of the cause.
    BTW. I ordered an Alto Cycling wheel set to replace them. Opinions please.
    Russian Troll Farmer
    Sep 2016
    I am a powerful, 215 lbs. rider. These wheels, ..... with 16/20 spokes ......
    Anybody else think this might be why it failed?
    "L'enfer, c'est les autres"
    Oct 2014
    Nope, looking at where the failure occurred, I'm going to go with poor design/engineering/manufacturing
    If the rider weight were the only problem, I would expect the problems to be with spokes, nipples, or the rim beds, not a crack parallel to the valve stem.
    I weigh more than the OP, and used to weigh a lot more than I do now, and have never had wheel problems, even with 16 spoke front wheels.
    Reputation: Srode's Avatar
    Aug 2012
    I'd put my money on the valve stem nut being too tight for the design.
    I can't see how a carbon fairing aluminum wheel would be structurally compromised with that crack though - I'd be asking Giant not getting opinions from shop or the internet though....
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Reputation: Lombard's Avatar
    May 2014
    My question would be which 16 spoke front wheels did you have? I am only 180lbs. and the only 16/20 spoke wheels I would ever ride would be Shimano. And I still wouldn't take these on extended rides into sparsely populated areas with spotty cell coverage. If you break a spoke on a 24+ spoke wheel, you can adjust the other spokes well enough to get home. If you break a spoke on a 16 or 20 spoke wheel, you are SOL.
    -- Warren Buffett
    Mar 2006
    I do. I was destroying breaking spokes and hubs on 16 /20 spoke wheels when I was 205lbs...... Four different models from three different brands. I was always in the 53 tooth chain ring and mashing. Wheels were failing on climbs, which tells me that they couldn't handle the torque I was dishing out. I changed my riding style to spin more. Problem hasn't returned. I don't want to say that is the case, but for me, it was. Goes to show that low spokes count wheels still aren't the best choice for many riders. If you have to change your riding style to get longer life out of them, it's not you. There's a reason higher spoke count wheels are recommended as the best all around wheels by wheel builders.
    May 2014
    Quote Originally Posted by terbennett View Post
    Exactly. For a low spoke count wheel to be strong, the rim has to be beefed up which negates any weight savings of a low spoke wheel.
    So why are there so many low spoke wheels? Because they are considered "sexy" and sex sells.
    -- Warren Buffett
  1. Trek not liable for failure to warn of carbon fiber failure
    By RichardT in forum General Cycling Discussion
    Last Post: 03-21-2015, 05:56 PM
  2. Replies: 10
    Last Post: 01-25-2013, 05:49 AM
  3. Frackin Hard Drives. . .Failure on Failure
    By Ridgetop in forum The Lounge
    Last Post: 05-21-2010, 09:46 AM
  4. Length of the aero section of Giant Aero Seatpost?
    By Ventruck in forum Components, Wrenching
    Last Post: 04-25-2010, 06:09 AM
  5. What is the most aero aero bar?
    By triple shot espresso in forum General Cycling Discussion
    Last Post: 05-05-2004, 09:30 AM
