Results 1 to 20 of 20
    Nov 2005
    After running a set of Zipp 454's for most of the summer, I switched back to my old Ultegra/ HED Belgium wheelset to help deal with the high winds coming off of the ocean. Strava times have stayed the same. Was expecting a slight decrease here or there.
    A wheelist
    Reputation: Mike T.'s Avatar
    more delete
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with motivation, information and resources.
    Nov 2005
    Any Star Wars fans out there with small wieners?
    Reputation: Oxtox's Avatar
    Aug 2006
    after getting a set of C24s, was able to do the Kessel Run in under 11 parsecs...
    Reputation: Notvintage's Avatar
    May 2013
    Quote Originally Posted by morgan1819 View Post
    Kind of confirms November Wheels post about aero wheels and fantasy gains. Waste of money really.
    Reputation: 73Bronco's Avatar
    May 2015
    Quote Originally Posted by Oxtox View Post
    You just made my day
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Sep 2011
    While I tend to agree that "in general", the difference in avg speed gained/lost for an avg spirited cyclist riding on the street, will be "almost zero gained/lost". However, the problem with using Strava times for such "averages" can be misleading. Why? Because on the street, a shallower wheels will "on average" accelerate faster from a stop sign or red light, while the aero wheels will be slightly faster on longer stretches of road without stop signs/red lights. In the end, any difference in "avg speed" resulting from faster acceleration (shallow wheels) and longer-but-sustained higher speed (aero wheels) will neutralize each other out, and thus your avg Strava times will remain essentially the same.
    But make no mistake, the aero wheels will definitely hold a higher avg speed in a long sustained effort on roads without much stop signs and red lights. Personally, going by my own unscientific observation, compared to my shallow alumuninum wheels, I think I average about 1 to maybe 1.5 mph faster with my 55mm Easton Aero 55 tubular wheels when going hard at 27-30 mph, especially if there is a slight tail or even cross-tail wind, I'd flying like a sail reaching 32-33 mph on the flat all by myself (not drafting a pack). It's very hard for me to reach 30 mph with shallow wheels unless there is a slight 2% downhill or a good tail wind.
    May 2013
    But make no mistake, the aero wheels will definitely hold a higher avg speed in a long sustained effort on roads without much. .
    The generalizations and fantasy ride speeds continue. I think deep dish pizza wheels make amateurs “think” they are riding fast by the vertical stiffness and “whooshing” sounds. Lol.
    Reputation: Srode's Avatar
    Aug 2012
    I see a difference of about 0.5 to 1mph out of the draft over say 28mph in the right wind conditions - Not a situation that is a high percentage of my ride time to be sure, its in sprints to a land mark in a group ride almost always, passing someone for a finish place. In this situation they can make the difference between 1st or 3rd place for sure. Otherwise I'm sure the contribute something on long solo rides like 100 and more but not something I have tried to or could quantify as there are too many other variables.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Notvintage View Post
    ^This.^
    Dec 2005
    Can you link it here? Can't find it but, I'd like to read it....
    Feb 2002
    Your numbers are significantly higher than the research suggests. The fastest wheels on the planet are about 0.4 mph faster than a 32 spoke box section rim setup at 25 mph. 0.3 mph faster at 20 mph.
    Aug 2012
    Maybe a bias high but they seem to be right in the hunt from what you quoted on the low side of the range I quoted wich is 0.5mph considering mph range is higher than your numbers and the wheels I'm comparing against are Shimano RS81s which are pretty much box section rims with fewer spokes. Enve 4.5s are not the fastest on the planet but they aren't slugs. Even at 0.3 mph that's the difference between losing a few places and winning on a high speed (which ends up being 31 to 32 mph on flat ones for a short period) shootout to a road sign in a weekend group ride so they can help in the right situation.
    On Edit - Here's a link with actual real world data not wind tunnel which has results higher than my estimate.
    https://www.cyclingweekly.com/videos...o-wheels-video
    Gravel Rocks
    Trek Domane
    Trek Crockett
    I'd be more interested in knowing the difference in watts required to go the same speed of, say, 25 or 20. Any idea?
    I don't do TTs and certainly not about to win a race via solo breakaway. And .3 won't impact my fun riding solo. I do my share of pulls but if it's too slow by .3 for anyone they can take over.
    Basically for my riding and races I don't see going .3 faster really mattering much.
    But if I'm using less watts to be where I want to be over the course of say 60 miles that could be a big deal. Or maybe it wouldn't. Probably impossible to measure the correlation between putting out a few less watts over the entire course and then being able to use what you saved when it matters.
    Dec 2005
    This is why there is such a huge difference in opinion on the importance of aero equipment here vs. say slowtwitch. 1.5s/km at 25mph just for a set of wheels is worth it for those trying to beat the clock. Not so much for everyday riders/commuters/enthusiast/touring riders.
    As far as watts go I'd wag 10W for 0.4mph..just a wag. Not enough to really notice on a group ride or even solo when varying position and effort. I've only been able to tease out differences in equipment when at threshold for long periods of time in the same position.
    With all that said, there is definitely something to wider rims (both internal and external). Depth is important as well as shape but, guys who neglect width are missing the boat.
    Dec 2005
    Just to add...tires (crr)are way more noticeable regarding speed differences than wheels imo. Put a bad rolling tire on those wide, deep wheels and you'll easily erase any gains.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    The only time I ever notice a difference in effort is while drafting behind something. I have many different bikes, with many different wheels and tires, my times are always comparable.
    Having said that a proper tuck makes a huge difference in speed. The person matters way more than the bike in pretty much every way you can think of.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't %^&* like that since I was an altar boy" Hank Moody
    Old and in the way.
    Aug 2014
    Earlier this season I had the opportunity to buy a set of Roval CLX 32 wheels used. I tried them for a week and was surprised. They felt different, but in the end no difference in speed. They're a bit lighter than my stock DT Swiss 470db, but no help, I guess. Even more surprising was that I was running GP 4000s II on the Rovals and GP 4 Season on the DT Swiss. I guess at the speeds I ride the differences aren't as pronounced as those that ride at higher speeds. I'm a 17-18MPH average rider.
    May 2014
    Quote Originally Posted by dmanthree View Post
    Yep. Lighter wheels will make you FEEL faster because they will accelerate better. Once up to speed, you will hardly notice a difference.
    Old and in the way.
    Aug 2014
    Needless to say, I passed on them. They're really nice wheels, but too expensive. I might buy a second set of wheels so I can run two sets of tires easily, but I'll look at aluminum from DT Swiss, Fulcrum, Easton, etc. Lots of choices.
    One thing I did notice about the carbon wheels: less gyroscopic stabilization coasting down hills at higher speeds. Definitely not as stable as the aluminum wheels.
  1. Actual photo, actual product
    By Mel Erickson in forum The Lounge
    Last Post: 07-17-2011, 02:15 PM
  2. Differences between Powertap Time and actual TT time?
    By stewie13 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 08-25-2009, 11:16 AM
  3. Contador gains time??
    By uzziefly in forum Pro Cycling - Tour de France
    Last Post: 09-21-2008, 09:06 AM
  4. average speed gains
    By lablover in forum Beginner's Corner
    Last Post: 06-09-2008, 09:01 AM
  5. Poal: Change name, change profession, change both?
    By mickey-mac in forum The Lounge
    Last Post: 06-11-2007, 12:07 PM
