Results 1 to 12 of 12
    .je
    .je is online now
    Lizard Person
    Aug 2012
    Question Help! Hub doesnt let cassettes mount correctly
    Maybe you folks could help me with a problem I'm having.
    I have a rear wheel with a Tiagra 4600 hub that goes on the trainer, and another 2 wheels used on the road, with a Bitex hub and a Mavic hub, and another bike with Formula hubs.
    When the wheel in question was new it would interchange with the others freely. Now it doesn't exactly do that. Any cassette on it sits too far in, so the largest 2 cogs dont engage, and the chain can be dropped off the small end. Doesnt happen on any of the other wheels regardless of the cassette used. Putting another spacer doesn't let the retaining ring engage threads.
    Iirc it might have started when I greased the bearings, but not sure. The freehub never came off. It does or did get squeezed in the trainer but that shouldn't change much.
    Totally conflustered. What can be done? Thx!
    Oct 2013
    Maybe you have too many gears on one.
    BANNED
    Feb 2002
    Quote Originally Posted by .je View Post
    Take some measurements. If an extra spacer doesn't let the lock ring engage, then that is not likely the issue. Measure the width of the cassettes on all of your wheels and the distance from the largest cog to the axle face (that touches the frame) and from the smallest cog to the axle face. If all these measurements match up between your wheels, then the problem is something else entirely. If they don't match (and the mismatch would have to be significant to cause the problem you describe) then you can start your explorations there.
    .je
    .je is online now
    Lizard Person
    Aug 2012
    Well, I'll do that, but the same cassette works on the other wheels, just not on this one. But, it used to... ?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    What Kerry said.
    Also, What kind of cassette are you using? Specific make and model. The lockring issue sounds like the wrong brand or size lockring.
    Jan 2010
    I think the OP may be talking about the need for RD adjustment, rather than the cassette not fitting.
    Is my understanding correct?
    There's sometimes a buggy.
    One.
    Quote Originally Posted by bikerjulio View Post
    yes, pretty sure.
    Not sure which is the wheel in question but either you didn't put it back together as it was before or, if it's the Mavic, you lost the Mavic spacer that came with the hub and are using a different size now.
    .je
    .je is online now
    Lizard Person
    Aug 2012
    I didn't lose any spacer. If you don't put that in the cassette is loose along the freehub, so it's there. My guess is that I just started to put too many spacers in my road hubs because it seemed to go together smoother that way. Will try to sort that out first.
    OK maybe I asked wrong: there's a Formula 9-speed hub, and a 4600 Tiagra hub. I took the 9 speed cassette off the working Formula hub, put it on the 4600 hub, and set up the trainer with this wheel, and the gears are all way, way off as described. That's a simpler way to explain this.
    I'll however look at the spacers as you suggested.
    If 'it' means you are using one spacer and it's the mavic wheel you indeed did lose a spacer.
    .je
    .je is online now
    Lizard Person
    Aug 2012
    Figured it out: When I repacked the bearings, I took off a collar that goes over the axle from the NDS, then when everything went back together, put it on the DS, so the hub now sat to the left the 5mm length of that collar ' a "spacer" if you will ' . Not coincidentally, I had to super-dish the wheel so it wouldn't rub the chain stay, for until-now unknown reasons.
    I switched the side the collar is on, and the gears all engage. Now I'll have to properly dish the wheel again. Thanks all (sorta)!
    Russian Troll Farmer
    Sep 2016
    You actually re-dished the wheel before sorting out the spacers? I guess you've never worked a a bike mechanic.......
    "L'enfer, c'est les autres"
    Oct 2013
    You cannot fix one fu with another fu, it will always be fu'd.
    In more pc words, if you fixed something and it presented another problem, go back to the first problem and fix it again.
    BANNED
  1. Replies: 11
    Last Post: 11-20-2015, 08:35 AM
  2. Let it snow, let it snow, let it snow
    By MikeBiker in forum The Lounge
    Last Post: 12-20-2006, 07:36 PM
  3. Seatpost doesnt fit in frame
    By steel515 in forum Components, Wrenching
    Last Post: 06-08-2005, 07:17 PM
  4. Why doesnt Armstrong enter Vuelta a Espana?
    By MountainPro in forum Pro Cycling - Tour de France
    Last Post: 09-21-2004, 01:07 PM
  5. why doesnt shimano give long bolts with their pedals????
    By benja15 in forum General Cycling Discussion
    Last Post: 07-22-2004, 03:48 PM
