Results 1 to 11 of 11
    Oct 2011
    Inner Tube Question: Michelin Aircomp ultralight
    MICHELIN AIRCOMP ULTRALIGHT ROAD inner tube says 18/23C tire it will work with on package. Is it possible to use with size 25 tires? Upgrading to newer rims that are the wider type which only handle 25 on up for tire size.
    Thanks
    Forever a Student
    Mar 2014
    I'd run it. I run pretty low pressures though.
    use a torque wrench
    Jan 2010
    at 70g it's really only medium weight in the WW scheme of things, where 100g is normal and 50g is really light.
    I wouldn't worry too much.
    There's sometimes a buggy.
    One.
    Reputation: velodog's Avatar
    Sep 2007
    I'm another that would use it.
    Too old to ride plastic
    Sep 2009
    I'm used them in 25s with no problems.
    Reputation: Lombard's Avatar
    May 2014
    Deleted.
    -- Warren Buffett
    Oct 2011
    Thanks for the replies will use them.
    I use 19-23 Tubes in 33mm tires. 25mm is most certainly no problem.
    Don't take me work for it though, blow up the tube outside the tire as see for yourself. Some real crappy tubes will blow at the seem pretty quick but most half decent ones go way beyond what they say.
    Oct 2011
    Will try that, have like 12 Michelin ultra lights in my draw bought when they were heavy discounted since I'm switching to Campy bora ultra 35 from my trusty neutron ultras was hoping to be able to use them.
    'brifter' is a lame word.
    It's a 2mm difference...it'll work just fine.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    Quote Originally Posted by gofast2wheeler View Post
    I've only got 20,000 miles on that setup so I can't tell how well they will work in the long term, but so far, so good.
  1. Michelin AirComp UltraLight Butyls
    By lalahsghost in forum Wheels and Tires
    Last Post: 10-25-2012, 07:58 AM
  2. Maxxis Ultralight tube question
    By piano,piano in forum Wheels and Tires
    Last Post: 12-15-2011, 06:56 PM
  3. Michelin A1 tube problems.
    By High Gear in forum General Cycling Discussion
    Last Post: 05-22-2011, 04:59 PM
  4. New Michelin Tire = New Michelin Tube?
    By jmess in forum Wheels and Tires
    Last Post: 05-19-2008, 08:35 AM
  5. michelin ultralight tubes?
    By CC09 in forum Wheels and Tires
    Last Post: 04-24-2006, 06:58 AM
