Results 1 to 17 of 17
    Nov 2006
    Lightweight, deep aluminum rims
    I'm looking for a rim to build a new wheelset to. Must be:
    Light, less than 500g
    Deep, 40mm or greater
    Wide, 21mm or wider
    Aluminum brake track (I don't care if its carbon faired)
    Does such a thing exist? Is something like that already in a factory wheelset? If not I need to decide if I value aluminum or depth more and choose between Pacenti and Enve.
    Thanks!
    Oct 2009
    Quote Originally Posted by kbiker3111 View Post
    Wide, 21mm or wider
    Thanks!
    I don't think a sub 500g 40mm deep aluminum rim exists. It would probably be more like 600-700g. The closest may be the American Classic 420 rim which is 34mm deep.
    Valley Cyclist Wheels www.valleycyclist.com
    Oct 2012
    No.
    No.
    Pacenti and H Plus Son are your best bets.
    May 2013
    Kinlin xc279 or xr380
    Mar 2013
    Quote Originally Posted by 2Bills View Post
    +1 on the xc279...
    Jun 2013
    The closest I have come across is the Fast Forward (FFWD) F4R-c rim at 38mm and 550g.
    Edit: Took some time to find, but those are 19.6mm wide.
    Specialized Allez Expert (2013)
    Scott Scale 40 (2006)
    Wide, 21mm or wider
    Aluminum brake track (I don't care if its carbon faired)Does such a thing exist? Is something like that already in a factory wheelset? If not I need to decide if I value aluminum or depth more and choose between Pacenti and Enve.Thanks!
    Sounds like the middle ground you're looking for is the Dura Ace C35.
    Nov 2006
    Looks like there are no standalone rims near what I was looking for but wheels from Giant, Shimano and Rolf have rims pretty close to what I'm looking for. Now getting the rims standalone is the next challenge...
    Mar 2006
    Quote Originally Posted by Full_Spectrum View Post
    No.
    No.
    +1...
    Mar 2010
    Quote Originally Posted by valleycyclist View Post
    Maybe I am wrong but the AC are in no way 21mm wide. I think they are 13mm internal width which translates to about 18mm external.
    Feb 2006
    If you want the rim deep for aero, you don't need to go that deep. Wide and rounded is best. The Pacenti SL23 and Kinlin XC279 are in the sweet spot for aluminum rims. If you want to go deeper you are better off with the latest generation carbon.
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Quote Originally Posted by rruff View Post
    This.
    I've said it many times before but depth isn't the most important factor to look for. Overall rim shape and profile is far more important than just depth alone.
    Sep 2005
    Wide, 21mm or wider
    Thanks!
    Factory wheelsets that meet your criteria are Hed Jet ($$$$) and the new Flo Cycling wheels (FLO Cycling Home - Aerodynamic Cycling Wheels). Both are carbon-faired deep section wheels with 23mm wide alloy rims. Neither are available for build-your-own (though both offer Clydesdale/Stallion builds).
    Reputation: Ventruck's Avatar
    Mar 2009
    I thought OP was looking for that 90's Vento/Shamal,etc look. Man I'd dig a pair of something like that myself.
    Sep 2005
    He did say "Aluminum brake track (I don't care if its carbon faired).
    The Flo 30 wheel looks quite interesting...a toroidal shaped wide alloy rim (similar to Zipp 101) that tests in the wind tunnel quite well (better than deeper V-section rims) and is still reasonably priced.
    Jan 2011
    I did recently notice that shimano makes a deeper section RS-80 now too. 50mm. 1700-ish grams. $750 at ribble plus more for shipping. not sure about rim width though. I would imagine that they're the standard 19-20mm width.
    Jun 2013
    Quote Originally Posted by charlox5 View Post
    The new RS-81 is 23mm wide, if I'm not mistaken. The old RS-80 might be 21, but I'm not completely sure.
  1. Lightweight aluminum clinchers....
    By Cni2i in forum Wheels and Tires
    Last Post: 04-26-2012, 07:18 AM
  2. Replies: 18
    Last Post: 01-04-2010, 12:07 AM
  3. Lightweight aluminum frame?
    By Sub in forum Bikes, Frames and Forks
    Last Post: 03-03-2008, 02:54 PM
  4. Deep(er) section tubular aluminum rims - options
    By powerste in forum Wheels and Tires
    Last Post: 03-14-2007, 10:47 AM
  5. deep aluminum clincher rims?
    By wooden legs in forum Wheels and Tires
    Last Post: 06-04-2006, 08:27 PM
