Results 1 to 8 of 8
    Jun 2005
    Looking for Wheel Storage Ideas
    Hi all,
    I'm looking for a way to store some wheelsets when they aren't being ridden. I was thinking others here have some solutions they might be willing to share. I want to get them off the garage floor and out of the way so they don't get knocked around. I'm open to building or buying whatever makes sense. Thanks.
    Feb 2005
    get some ladder hooks (https://www.homedepot.com/p/Everbilt...7954/202249701) either of the top 2 will work. Screw a 2 x6 onto the wall and into the studs with a 3" sheetrock screw and space the hooks about 10 - 15 inches apart so the wheels overlap. You can easily get 6 wheels in a 6 foot space and only stick out about 6". Mount the 2 x 6 about 6 inches from the ceiling and you won't be taking up any lower wall space either. My bikes hang by the front wheel underneath the wheel rack. You can also put in eyebolts into the 2 x 6 and run cables to lock the wheels.
    Jun 2005
    Thanks. That just might work in one of the spaces I have.
    Reputation: velodog's Avatar
    Sep 2007
    I've got a couple of those ladder hooks screwed into the ceiling about 6ft apart with a piece of 1/2" electrical thinwall pipe spanning the gap. I string the wheels onto the thinwall between the hooks. If the most used wheels are the outer most it isn't too much trouble getting them unstrung and down.
    It might work just as well if it was mounted on the wall.
    Too old to ride plastic
    Jun 2005
    Thanks Velodog. I'm looking at something on the wall as my ceiling is probably 12 feet in the garage, and I want something reasonably accessible, with no more than a footstool while also being well out of the way. My wife expects that both cars will fit in the garage, so . . .
    Russian Troll Farmer
    Sep 2016
    I had some PVC pipe laying around, so I bought 2 sets of plastic bathroom curtain rod end holders, mounted them between the overhead floor joists in my basement, cut the PVC to the right length, and I can easily fit a wheelset hanging from each.
    "L'enfer, c'est les autres"
    Jan 2011
    If you want something a little fancier than a homemade solution, here is something that a friend of mine makes and sells. I have one and it is really great
    Foothill Products Bicycle Wheel Storage
    Jun 2005
    That's nice looking MoPho, but I did this:
  1. Replies: 18
    Last Post: 11-23-2010, 09:15 AM
  2. Looking for some kind of inexpensive storage/display stand
    By sqwk77 in forum General Cycling Discussion
    Last Post: 10-16-2010, 09:00 AM
  3. Cubicle Bicycle Storage Ideas Needed
    By gtran1502 in forum General Cycling Discussion
    Last Post: 08-20-2010, 09:10 AM
  4. storage ideas for step in stakes
    By jroden in forum Cyclocross
    Last Post: 11-16-2009, 07:13 AM
  5. need ideas with storage in smaller CA garage
    By gersting in forum General Cycling Discussion
    Last Post: 05-19-2008, 05:13 PM
