Results 1 to 15 of 15
    Oct 2010
    michelin pro4 service course tire pressure
    Do these need more or less PSI than usual? I couldn't quite figure it out.
    It's smooth but it's a bit buzzy
    Reputation: RyleyinSTL's Avatar
    Aug 2012
    That will depend greatly on what your "normal" PSI is, what width you purchased and what ride quality v/s grip characteristics you prefer.
    Trek Domane 5.2
    Cannondale Rush SL
    Oct 2010
    i'm running 105-110 on GP4000s 23 for example?
    the Pro4 seem to corner well and have lower rolling resistance.
    Aug 2012
    Quote Originally Posted by PoorCyclist View Post
    I will assume you bought 23mm....
    Run the same pressure. Evaluate performance. Good? Bad? Adjust pressure if required and evaluate performance again.
    Trek Domane 5.2
    Cannondale Rush SL
    Oct 2011
    I run 100 in the front and 105 in the rear. Works great for me.
    May 2008
    Quote Originally Posted by Rokh On View Post
    And the both of you weigh...how much again?
    Nov 2011
    I've got the Boyd Vitesse 23mm rims with the Pro 4 endurance 25 mm tires...I'm 185lbs...what pressure would you recommend? i've been running 95 psi front, 100 psi rear...is that to high? what is the lowest i should run?
    Reputation: askmass's Avatar
    Sep 2009
    I'm running Pro 4's in size 25 @ 100 front and 110 psi rear, and for me it's the sweet spot.
    That's about 15-25 less psi than what I always ran on Vitt EVO and Diamante tires.
    I weigh 187.
    YMMV.
    Discover Muscle And Sports Science, the source for Legitimate,
    Patent Technology muscle, fitness & sports supplements.
    http://www.musclemass.com
    Since 1993, Your Success is our success.
    Jul 2011
    Reputation: phoehn9111's Avatar
    May 2005
    145 lbs, 23c, latex tubes, 120psi both, very nice ride, spin up very quickly,
    hold speed remarkably well.
    All I said was that our son, the apple of our three eyes, Martha being a cyclops, our son is a beanbag, and you get testy!
    Reputation: looigi's Avatar
    Nov 2010
    Ouch. 165lb 90 front 100 rear with 23c on HED C2 rims.
    ... 'cuz that's how I roll.
    Aug 2012
    Pitts Pilot
    Dec 2011
    Pro 4 25mm on HED C2 rims (23mm) - Weight 145
    80 front - 85 rear
    really nice in all ways
    Jan 2009
    Quote Originally Posted by askmass View Post
    I weigh 187.
    YMMV.
    What width rims (standard? 23mm?) do you use?
    Reputation: new2rd's Avatar
    Aug 2010
    There's so many variables in this equation:
    road surface
    rider weight
    rim profile
    wheel characteristics
Sea Otter Classic
Contest
