Results 1 to 24 of 24
    Nov 2014
    Mixing 23s and 25s
    Any beneits/drawbacks to running 25c for a rear and 23c in front? Generally use the same model Vittoria clincher.
    thx,
    Reputation: Lombard's Avatar
    May 2014
    I don't see any reason why you can't do this. But I don't see any reason why you would want to do this.
    If you want to run a 25mm tire in back, why would you not want to run a 25mm tire in front?
    Nov 2014
    I guess because I expect to enjoy the comfort more in the rear and in theory 23c more aero in the front. I suppose more than anything, because my supply on hand works better using the 25c tires in the rear, allowing me to go through some of my stock of 23c tires by using them in the front. Lots of theoretical going on here.
    May 2014
    Well it is true that there is more load in your rear tire. So if you want to have your front and rear tire pressure the same (for whatever reason, I don't know) this would be the way to go.
    IMO, I'd rather have the ride be softer in front. My arse can deal with more shock than my hands.
    Aero? I doubt you will notice a difference, really.
    Nov 2014
    All good points and I especially agree about the shock in the bars up front. This may just be a way for me to use up my 23c stock (seems like the only size I used to use to come close to the sewups I raced on). Once, I have run them out, I can enjoy the 25c all around. thx.
    May 2014
    Quote Originally Posted by GKSki View Post
    Sounds like a good solution. Or you can sell your leftover stock of 23mm tires on eBay.
    Back in the day when everyone believed that skinny tires were faster, I used to run a 20 up front and a 23 in the rear. Never had an issue (other than harsh ride)
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    There's absolutely nothing wrong with doing it. Continental sells the Grand Prix Attack & Force set which is a 23F/25R.
    https://www.continental-tires.com/bi...tack-and-force
    Running the same pressure front/rear is a nice feature. But beyond that I don't know if there's really much benefit (other than using up your stock). Aerodynamics has as much (if not more) to do with the rim width than just the tire width.
    I did that for a few years.
    You own the tires already. Trying it for yourself if the best way to answer your question.
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Same here, been doing it for years without a drawback, and on my one bike I couldn't fit a 25 in (an older Tarmac), I ran a tubeless 23 for the increased comfort.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    'brifter' is a lame word.
    Me too, 23 fr/25rr.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: Srode's Avatar
    Aug 2012
    The only drawback I can see is you need to keep more tires on hand for spares.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Feb 2002
    You should be aware that tires wear out due to power transfer, not mileage. The power transfer (whether pedaling power or braking power) causes the tread rubber to be scrubbed off. I have put over 6,000 miles on a front tire with essentially zero weight loss. A front tire may get cut, crazed, and otherwise aged but it won't wear out due to tread loss. Thus, your stock of 23mm tires will last a very, very, very long time.
    The ride of 25s is better than 23s, but unless your weight is such that you have to pump a rear 23 to really high pressures, you should just mount your oldest tires and ride them until they wear out.
    May 2014
    This is true. A front tire lasts me much longer than a rear. When the rear wears out, I transfer the front to the rear, then put on a new front. As a result, I don't know how long a front tire would actually last if it stayed there, but my guess from looking at the wear (or lack thereof), more than twice as long as the rear.
    Not a climber
    Reputation: dcorn's Avatar
    Sep 2011
    My Aeroad came this way. Canyon says the same thing, narrower tire up front for better aero. But the wheels that come on it are 17mm wide, so the tires actually measured 25/27mm. I swapped them out for 32s, I want a lot of comfort haha.
    May 2014
    Quote Originally Posted by dcorn View Post
    Nothing wrong with comfort. If your frame can fit'em, buy'em.
    pmf
    pmf is offline
    I used to do 20F/23R back when only tourists rode big tires.
    Don't those special tires Mavic makes for their special wheels differ in size front and back?
    changingleaf
    Aug 2009
    Benefit of having a more cushion in the rear where the extra weight is. drawback is slightly more weight. Cushion and pinch flat protection is going to outweigh the extra weight of the tire.
    Pooped a refrigerator.
    Reputation: SauronHimself's Avatar
    Nov 2012
    The only drawback to running two different tire sizes is you can't rotate the front to the rear when the rear gets worn. Well, you can, but it would defeat the original purpose of running differing sizes.
    Ghurarmu shirkush’ agh azgushu. Zant ya apakurizak. Gűl-n’ anakhizak.
    May 2014
    Quote Originally Posted by SauronHimself View Post
    Yes and no. The OP's original purpose of running different sizes is to use up his supply of 23mm tires.
    Feb 2002
    Re-read what I posted. Zero wear on the front after 6,000 miles. If you simply left the tire on the front you would replace it because it was all cut up or the rubber was cracking, not because it was worn out. The rubber thickness would still be there.
    May 2014
    Point taken, but zero wear? After 3000 miles when I retire the rear tire and move the front to the rear, I would say very little wear, but not zero. While there are no drive forces in front, there are still braking forces as well as corning forces.
    Mar 2006
    I actually run 23c in the front and 25 in the rear on one of my bikes for the same reason. Been doing it for about a month now and am satisfied with it. Not sure that I benefit from it but I don't like the squishy feeling I get riding at lower pressures in the front. Everyone has their preferences.
    Reputation: Oxtox's Avatar
    Aug 2006
    currently have 8700 miles on the front tire (Conti 4KIIS). the wear indicators don't look appreciably different from those on a brand new tire.
  1. 25s or 28s for a Cervelo RS
    By Stogaguy in forum Wheels and Tires
    Last Post: 08-11-2012, 08:05 PM
  2. PBK - Conti Gatorskins folding 700/23 or 25s $30
    By ctrl_alt_id in forum Hot Deals
    Last Post: 11-17-2009, 01:05 PM
  3. From 23s to 25s and recalibration of the puter…
    By Elfstone in forum General Cycling Discussion
    Last Post: 10-02-2007, 05:14 AM
  4. 28s to 25s
    By Beethoven in forum Wheels and Tires
    Last Post: 10-02-2006, 01:08 PM
  5. 700 x 23s vs. 700 x 25s and comfort?
    By GiantNigel in forum Wheels and Tires
    Last Post: 11-30-2005, 03:16 PM
