Results 1 to 5 of 5
    Feb 2010
    Most durable rim/wheel for 27.5'' e-bike
    Hi guys -
    I've got a customer who weights 260 and commutes on his e-bike about 40 miles/day 5 days/week. He's blown up his rear wheel, and I'm building him a new one.
    What's the burliest 27.5 rim you're aware of? Any recommendations?
    a real member's member
    Jul 2016
    what's on the front?
    32h?
    tubeless?
    is he curb hopping?
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by masont View Post
    Hi guys -
    Probably something designed for downhill or enduro mountain biking like this:
    https://www.dtswiss.com/en/products/.../enduro/e-512/
    https://www.wtb.com/collections/650b...frequency-team
    And laced with no less than 32 spokes and brass nipples. 36 spokes would be preferable, but that's a hard find in this size.
    Feb 2002
    Hi guys -
    What is the cause of the failure? The problem you have is that the key to durability is more spokes, and you're stuck with the e-hub (I assume). Agree with the suggestion to look for MTB rims, and assume that heavier will be more durable. Not always true but it's about all you have to go on.
    Feb 2010
    He's started blowing spokes. Rim is bent, no way to have even tension and a true rim, etc.
    It's a mid-drive. I can build him up anything I want, as long as it's 27.5. Stock hub is 32h, I could reuse - I've seen some e-bike specific wheels, but no rims with a thicker spoke bed, etc.
  1. Most durable 650c tire with color options?
    By Morisato in forum General Cycling Discussion
    Last Post: 05-03-2011, 03:52 PM
  2. Most Durable Biking Shorts (~$50)
    By skibud2 in forum General Cycling Discussion
    Last Post: 05-25-2009, 02:38 PM
  3. most reliable/ durable clincher tires
    By jhenry4 in forum Wheels and Tires
    Last Post: 03-20-2006, 12:04 PM
  4. durable, good grip and most of all, easy to mount tire?
    By bluesaint in forum Wheels and Tires
    Last Post: 02-27-2006, 03:43 AM
  5. most durable tubular tyre
    By kenyonCycleist in forum Wheels and Tires
    Last Post: 02-05-2006, 08:54 PM
