Results 1 to 2 of 2
    Reputation: Britchap's Avatar
    Dec 2005
    Mystery freehub body
    I have a pair of Vision Team 30 wheels (the same as FSA Gossamer) which I commute/train on. Recently after a couple of wet rides the freehub developed a loud ratcheting sound and a sort of bearing grumble so I thought I should take a look in there and clean/relube. I have a set of Fulcrum 3 which are very easy to maintain, 10mm hex wrench, its off, lubed and back on in a couple of minutes.
    I thought the Visions would be the same but no such luck. A quick scan of the Vision/FSA websites turned up no technical information so I went for it, got the axle out and tried my 10mm hex on the freehub body. It was too small. I guessed at 11mm or 12mm so I mail ordered both (not available anywhere locally). Stuck the 11mm in the drive side and cranked it CCW but got nowhere. At this point I take it to the LBS who figure out it needs to come off by loosening the 12mm bolt from the non-drive side - they did not have a 12mm so I did it myself at home. So I got the free hub body off, popped off the seal at the back and tried to drip lube into it. I put it back together and it is quieter but still a bit rough. I think I need a new one.
    I have emailed Vision/FSA but have had no reply, these are some kind of generic no-name hub, the free hub body looks like this:
    A-Class Freehub Body > Components > Wheel Goods > Hub Small Parts | Jenson USA Online Bike Shop
    What do I measure or look for in order to figure what it is so I can get a new one? The wheel bearings themselves are perfect, its just the freehub that is rough - should I care?
    Dec 2005
    FSA have replied. Their guy says its the in-house PRA hub - nah, that's found on much fancier wheels than these, like the Trimax 30. Still a mystery.
    I aim to take the wheel out for a good thrashing tomorrow to check out the level of noise. If its still rough I'll pop off the freehub and have the LBS figure it out.
  1. Got 8-Speed Freehub Body?
    By Scott in MD in forum Campagnolo
    Last Post: 09-11-2010, 10:54 PM
  2. Stripped Freehub Body
    By wsrobert in forum Wheels and Tires
    Last Post: 04-13-2010, 04:52 PM
  3. freehub body
    By jhamlin38 in forum Components, Wrenching
    Last Post: 12-15-2007, 09:09 AM
  4. Please Help Me Identify this Freehub Body
    By Mud in forum Components, Wrenching
    Last Post: 05-29-2007, 06:02 PM
  5. Anybody ID this Freehub Body?...
    By TurboTurtle in forum Components, Wrenching
    Last Post: 04-23-2005, 08:43 PM
Sea Otter Classic
Contest
