Results 1 to 5 of 5
    Sep 2006
    Need 25mm tires for bike with tight clearances
    Hi
    My Ridley Helium takes a 25mm tire with a max rim width of 28mm. With wider rims (17mm internal, 23mm internal), a Conti 4000s 25mm is too big under the fork. Any suggestions for decent true to size clincher tires? if not, will move to 23mm Conti 4000s which actually measure 24.7mm on my current wheels. Thanks
    changingleaf
    Aug 2009
    I would stick with the 23mm conti up front since it looks like that tire may already maximize the space available, then I would run a 25 in the rear if it fits.
    May 2012
    Interestingly, same tire and a rim with identical dims fit in the stock fork on my older Ridley Gladius frame with about 3mm clearance.
    I had a friend who could run 25 wide tires on narrow rims, or 23 wide tires on wider rims. He said he preferred the wide rim and narrow tire combo best.
    Sep 2006
    Thanks for the replies. The chain stay clearance is a little better for 25mm Continentals but still tight. Will just use 23mm Conti 4000s
  1. 23mm tire on 25mm mm rim or 25mm tires on 20.5 rims - questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 01-09-2017, 05:37 AM
  2. hongfu fm069 + 25mm wide carbon wheels + 25mm gp4000s?
    By hernluis in forum Bikes, Frames and Forks
    Last Post: 05-05-2015, 10:23 AM
  3. BH G5 Tire clearances?
    By benInMA in forum Other Builders
    Last Post: 02-12-2012, 09:50 AM
  4. Roadies with larger tire clearances - offroad and curbs OK?
    By CoastieTX in forum General Cycling Discussion
    Last Post: 04-29-2010, 04:33 AM
  5. Big tires and brake clearances
    By BBJ in forum Commuting, Touring and Ride Reports
    Last Post: 07-23-2006, 05:32 PM
