Results 1 to 9 of 9
    Apr 2015
    Nipple Size for Archetype Rim
    Building up a HSon Archetype - Height: 25 mm -Width: 23 mm - any reason not to use 12mm nips with DT Comp spokes?
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    14mm gives a little extra space so wrench doesn't scratch up rim.
    .je
    .je is online now
    Lizard Person
    Aug 2012
    I used the 14mm. I'd said 12mm earlier.
    Here is what sticks out. You wouldn't scratch the rim with a wrench with a 12mm nipple.
    Reputation: Lombard's Avatar
    May 2014
    If you are using DT Swiss nipples, the problem with 14 or 16mm nipples is that the thread is also longer. If you are using spokes with a standard length thread, it will bottom out sooner before the tip of the spoke reaches the top of the nipple. On a 14mm nipple, this will give you no room for spoke length error. On a 16mm nipple, you will never get the tip of the spoke into the nipple head. A spoke tip that never reaches or just barely reaches the head will be weaker and prone to breakage. See the photo below courtesy of Roger Musson.
    I would seriously stick with 12mm nipples. I have never had a problem scratching a rim with 12mm nipples. Get a good quality 4-sided spoke wrench like this one. Not cheap, but well worth it:
    P&K Lie Spoke Wrench - Wheel Fanatyk
    Attached Thumbnails Attached Thumbnails Nipple Size for Archetype Rim-spokes-nipples.jpg
    Quote Originally Posted by ergott View Post
    Yep, Definately 14m Sapim is the way to go. For this reason.
    May 2014
    Quote Originally Posted by Enoch562 View Post
    Are Sapim threads the same length for all lengths of nipples? Can they be used with DT spokes?
    If you dont know the answer, you prolly should limit your responses
    wheelbuilder
    Feb 2006
    Sapim 14mm has the same thread engagement as 12mm which is relatively the same for both Sapim and DT. Totally compatible.
    What I don't like about DT is they only forge about 8 or 9mm of thread on spokes. Easier to bottom out than Sapim.
    Sent from my SM-G950U using Tapatalk
    May 2014
    If you dont the answer, you prolly should limit your responses
    Heavy handed. I PROLLY shouldn't respond, but here it is. I use DT spokes and nipples for my wheel builds as that is what my bike shop has access to and I like to support them. My responses here are based on my own experience building wheels and what I have learned on the subject.
    And I can honestly say I have never scratched a rim using 12mm nipples and a good spoke wrench.
    Mmmmkay?
  1. Replies: 7
    Last Post: 12-25-2014, 03:02 PM
  2. Zipp rim - spoke nipple holes
    By tom_h in forum Wheels and Tires
    Last Post: 11-02-2010, 07:51 AM
  3. Lubricate Nipple to Rim?
    By TomBrooklyn in forum Components, Wrenching
    Last Post: 09-24-2010, 07:01 AM
  4. nipple came off rim
    By clipz in forum Components, Wrenching
    Last Post: 12-02-2009, 06:15 AM
  5. Kinlin xr270 rim hole offset and nipple seats?
    By GH-Mike in forum Wheels and Tires
    Last Post: 03-05-2009, 12:00 PM
