Results 1 to 10 of 10
    Jan 2009
    non-moving rim strips?
    I have rim strips (plastic) and maybe even velox which move and cause a flat.
    I think because I uninstall tires often and the tire lever digs under the strip.
    Does anyone else have this problem?
    I am thinking veloplugs
    Oct 2009
    I use veloplugs on one set of wheels and cloth velox tape on the other set. Both solutions work perfectly.
    I gave up on plastic rims strips many years ago and they don't seem to have improved any.
    More carbon fiber please!
    May 2004
    Strapping tape works well and is lighter than rim tape.
    http://inlinethumb36.webshots.com/48...600x600Q85.jpg'05 Giant NRS C1 & '06 Giant TCR Advanced
    '68 Schwinn Typhoon
    Old and Fixed, Moderator
    Jan 2002
    Velox.....Nearly every LBS in the US has a box of them sitting somewhere in the shop
    Dave Hickey/ Fort Worth
    Sep 2010
    I use Velox rim tape and never had an issue with tube damage. I might switch to Veloplugs in an effort to make it easier to install tires on my rims.
    Adventure Seeker
    Reputation: Peanya's Avatar
    Jun 2008
    I don't see how Velox tape could move, assuming you didn't install it poorly.
    I have a single track mind
    likes to eat donuts
    Reputation: piano,piano's Avatar
    Jun 2005
    I'm now using Veloplugs with my Kinlin (niobium) rims. Some people had mentioned that the red Veloplugs were just a little too loose fitting for the Kinlins spoke holes, but suggested to slightly bend the prongs outward for a tighter fit. I did that, and they fit and work very well as a result. I've also had great experience with Veloflex tape as well.
    “The secret of life is honesty and fair dealing. If you can fake that, you've got it made.”
    -Groucho Marx
    Nov 2006
    Velox and Velox only. Run the plugs with latex tubes, and you'll be changing a flat...
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Quote Originally Posted by Peanya
    Agreed. I think you just need to be a bit more conscious of where the rim strip is relative to the lever when changing a tire. Velox is all that I run on my personal bikes. However we sell quite a few of the FSA rims strips and those seem to hold their elasticity for quite a long time.
    Reputation: RJohn's Avatar
    Mar 2009
    Quote Originally Posted by been200mph
    ditto. Works fine. Lasts a long time and it's cheap.
