Results 1 to 7 of 7
    Apr 2015
    Proper Tension for DT Comps + HED Belgium
    Wheel building newb and just got a Park Tension Meter. Quick quesiton - are DT Competition Double Butted spokes considered a 1.8 thickness?
    I have a rear 32h Hed Belgium C2 / Ultegra Hub that's taken some pretty heavy abuse from a 230lb rider and it keeps coming out of true.
    First Q: My meter reads 26-27 for almost all my drive side spokes - which if that translates to 1.8 - is off the chart - over 167. So wondering if I should unwind all the spokes and basically start over on that wheel.
    Second Q: How do you know when I rim is bent to the point it needs replacing? I seem to remember my LBS last summer saying this rim took what looked like a curb hit. So I'm wondering when I had them true it - if the high numbers are cause they're trying to true out a bent rim?
    Oct 2009
    I have a Hed Belgium rim/wheel that I bulit, I weight 225 and my Ds spokes are 22/23 on my Park tension meter which is about 1200 kgf which is about what this rim calls for, I rarely have to true my wheel an then its just a liitle bit. Yes I would say 26-27 is high, If the rim is bent so bad that they had to true it that tight, I would probably say you need a new rim, but take it to a shop with a known good wheel builder an have him check it first.
    'brifter' is a lame word.
    2.0-1.8-2.0 Comps? You should be shooting for 22-23 as VR posted. That said, when was your Park tension meter last calibrated?
    I work for some bike racers
    and a bunch of skateboards
    Apr 2015
    2.0-1.8-2.0 - yes.
    Never calibrated - new out of the box - do you need to calibrate a new one?
    Quote Originally Posted by jmcg333 View Post
    2.0-1.8-2.0 - yes.
    It should be fine.
    Apr 2015
    Quote Originally Posted by Ventura Roubaix View Post
    thanks so much, this is exactly why I'm going to figure out how to build/service my own wheels ...
    Reputation: Lombard's Avatar
    May 2014
    Yes. It's the 1.8mm section that you are putting the tensiometer on, so that's the part of the chart you should read.
    How many miles are on this wheel? The components you are using are pretty robust. What do you mean by "abuse"?
    First off, yes, this is too high. The HED C2 can take 130kgF or around 23-24 on the meter. Keep in mind that when you mount and inflate a tire to road pressures, this will decrease your tensions slightly (about 1 graduation on the meter). One warning sign that you have tensioned the wheel past the limits that the rim can handle is that you will have a wave in the wheel you simply will not be able to get rid of regardless of how many small adjustments you make.
    Are all your readings relatively equal all around the DS of the wheel when the wheel is trued or are there tension disparities of more than 1-2 graduations? If you cannot equalize tensions AND make the wheel true at the same time, there is probably a bend.
    -- Warren Buffett
  1. Hed Belgium plus or Mavic CXP 33 rims
    By Mark H in forum Wheels and Tires
    Last Post: 02-29-2016, 07:58 PM
  2. Hed Belgium C2 rim Velo plug size?
    By zaragarcia in forum Wheels and Tires
    Last Post: 07-27-2011, 06:13 AM
  3. HED Belgium rims- thoughts and experiences?
    By dankilling in forum Cyclocross
    Last Post: 04-13-2011, 07:56 PM
  4. 24/28 or 28/32 for DA/HED Belgium C2 Build
    By grande in forum Wheels and Tires
    Last Post: 04-03-2011, 08:47 AM
  5. ksyrium sl or HED belgium c2 with dt240 hubs?
    By sdlesko in forum Wheels and Tires
    Last Post: 03-13-2011, 06:22 AM
