Results 1 to 20 of 20
    Aug 2015
    PSI going from 25 to 28c tires
    I'm a 6'6" 230lb rider on a Domane with GP4000SII tires. I've been running 100psi front and rear for the longest time and recently tried 90f/95r and it felt fine. On my CX bike, I just got the 28c version of the same tires for my road wheelset (CX bike doubles as winter road bike). What would be a good starting PSI for these? 70/70? 80/80?
    'brifter' is a lame word.
    Quote Originally Posted by thisisthebeave View Post
    I'm a 6'6" 230lb rider on a Domane with GP4000SII tires. I've been running 100psi front and rear for the longest time and recently tried 90f/95r and it felt fine. On my CX bike, I just got the 28c version of the same tires. What would be a good starting PSI for these? 70/70? 80/80?
    I saw a test recently (and linked it in another thread here...somewhere) that concluded you should reduce pressure about 10psi for every size larger tire to maintain the same tension on the surface of the tire. So that would suggest about 80f/85r for the 28mm tire. I'd start there and see what you think.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    Yup. The 10% number comes up again and again as a good starting point.
    May 2011
    But more to the point, why are you running only 28mm tires on a CX bike? That high of a tire pressure on a CX course is going to cause you cornering grip problems. Better to go 32mm tubeless or tubular for CX where folks run pressures down around 20-30 psi (maybe 35).
    Well, you know, that's just, like, your opinion man. - The Dude
    Quote Originally Posted by OldChipper View Post
    I don't know why he is but CX bike doesn't necessarily mean CX riding. I use my CX bike for road and good shape gravel roads with 28mm tires quite often.
    Aug 2015
    This guy is right!
    I re-read my original post and it wasn't clear so I edited. My CX bike doubles as my winter road bike.
    Reputation: Lombard's Avatar
    May 2014
    Why so little difference between front and rear? I 'm now running my 28mm tires at 70F/90R. Any reason not to do this?
    Just for the OP since he was using a 5psi difference to start. I'd recommend more of a difference like you (and I) both use. Depends on the bike and rider position to a certain degree. A TT bike would work better w/ the same pressure front/rear, an endurance bike or something w/ less handlebar drop and thus less weight on the front tire would work better w/ a bigger differential.
    Curmudgeon
    Reputation: SHIF's Avatar
    Jul 2009
    Here is a chart from Michelin Tires that's a good starting point.
    Quote Originally Posted by SHIF View Post
Name:	tire pressure vs size.jpg
    The pressures on that chart are wayyy too high.
    changingleaf
    Aug 2009
    Rim width and type of tire affect the optimal tire pressure. But terrain may be the biggest factor. If you ride where there's a lot of potholes and you're in a group where you can't see them coming you may want to increase pressure a bit to avoid pinch flats.
    Here's Enve's recommendation for tubeless tires, which may seem low, but seems to work well for me. Note, not all tires of a given size measure the same.
    Attached Thumbnails Attached Thumbnails PSI going from 25 to 28c tires-pressuresnipimage.jpg
    Quote Originally Posted by changingleaf View Post
    For my weight class anyway, yes, it does seem low on the left for 23mm. But they don't drop a lot as tires get bigger so it starts to not seem low as I work my way right into bigger tires on the chart.
    Definitely looks reasonable though. I use tubes and I'm pretty sure my rims are not as wide as Enve. Factor that in and I'd probably be right about where the chart is for 23mm tires (if I still used them). 33mm is the biggest I use frequently and even with tubes I'm pretty much the same or even below the chart if I think I can get away with it which I generally can except for trails with exposed roots.
    Definitely one of the better 'charts' I've seen and the only one I can recall from a tire or rim maker that didn't appear to be based on 'wisdom' from 1972.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    I'm close to your weight (215 lbs). When I was running 25c tires, I ran tire pressure at 90 rear, 80 front. I since jumped to 28c tires. Tire pressure is now at 80 rear, 75 front. And I'm going to drop the psi another 5 f/r. Trying to find the balance between comfort and flat protection. Try the tire pressure at 80/80 and go from there.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Aug 2015
    Agree, I'm 230 and run less than the 180 recommendation and never pinch flat
    Russian Troll Farmer
    Sep 2016
    Here's my method for calculating tire pressures over different sizes:
    I weigh 175, and I have one bike with 23mm tires, one with 28mm tires, one with 42mm tires. From flat, I use my floor pump, and give 15 full strokes on the rear tire, and 13 strokes on the front. Works perfectly. Works out to about 90/100 on the 23's, 70/80 on the 28's, and about 35/40 on the 42's.
    "L'enfer, c'est les autres"
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    I gotta ask...what hand pump gives 85-90 psi with 15 strokes?
    May 2014
    Quote Originally Posted by rideit View Post
    My thoughts exactly.
    Sep 2016
    Sorry, that's a FLOOR pump, typical Nashbar model from about 10 years ago. It seems that the "perfect pressure" is dependent on a consistent uncompressed volume over different tire sizes. Not exactly rocket science....
    Feb 2006
    EDIT-- I just noticed that this is a somewhat old thread, with a couple new comments. (Yeah, my floor pump does maybe 5 psi per stroke, so more than 15 strokes to fill a tire.)
    I'll leave these comments anyway.
    A lot of riders post their inflation numbers with the front just 5 psi lower. The front can often be much lower.
    Lower pressures on the front really help with rough road vibrations.
    Too low, and there's a risk of pinch flats when the tire bottoms out and mashes the tube between the tire tread and the rim edge. But pinch flats are more likely on sharper edged hits and at higher speeds.
    The GP4000S 28mm have been reported to be actually 30-32mm. So charts showing 28mm can likely go lower pressure for GP4000S
    This tire pressure calculator gives me a good starting point.
    Deducting 15% for the front tire is a good ratio for a 45% front to 55% rear weight distribution. (The actual difference is about 22%: 55/45=1.22, but I don't want the front "too" low.)
    Scroll down, use the "fully dressed rider + bike" section, and the "45%-55%" weight distribution.
    I have 25mm tires on wide HED rims, measuring 29mm inflated.
    The calculator tells me, at 170 pounds+20 bike: 65psi front and 80 psi rear for a 28mm. That's actually what I use. I've tried 70F 85R and the ride isn't any faster, but it's not as comfy on rough roads. I could likely use 60F 75R, but it's fine as is.
    For you, conservatively at 230+25 bike+rider+water+tools, etc:
    25mm:
    102 front, 127 rear!
    28mm:
    86 front, 106 rear.
    I'd try 100-105 rear, and 80-90 front. See how it rides. Try a test ride with a little more pressure to compare.
    For 32mm, it says:
    67 front, 82 rear. (even moderately wider tires have a lot more air volume! )
    So if it's actually about 30mm, you might try:
    90 rear, and 75 front.
    I want to see a slight bulge in the tire sidewalls if I look down while riding.
    Feb 2006
    Why so much lower for a few mm wider tire?
    Tire pressures are related to the air volume inside the tire. The area of a circle is pi x (diameter / 2) ^2. The volume is area x distance around the rim, which is basically the same with different sized tires. close enough.
    Assuming a circular cross section of the tire + rim:
    25mm
    490 sq mm cross section.
    28mm
    615 sq mm. That's 25% larger! Just 3mm wider.
    32mm
    804 sq mm. That's 64% larger! This is why the pressures can be reduced so much.
  1. Can I run 28c tires without going to 57mm brakes
    By chrisclougherty in forum Components, Wrenching
    Last Post: 02-24-2012, 09:51 AM
  2. Big difference between 25c and 28c tires?
    By boomer-sooner in forum Cannondale
    Last Post: 09-28-2007, 03:07 AM
  3. 700 x 28c tires
    By Hugh Strickland in forum Wheels and Tires
    Last Post: 03-23-2007, 07:54 PM
  4. Tires Max psi is 125. Pump is 115 psi
    By dbmcclus in forum Beginner's Corner
    Last Post: 11-28-2005, 08:19 AM
  5. 28c diamond tread tires
    By euro-trash in forum Cyclocross
    Last Post: 08-06-2004, 08:43 AM
