Results 1 to 21 of 21
    What the what???
    Jul 2009
    Rebuilding a "classic" wheel
    I managed to score a free set of wheels off of a 1987 Schwinn Traveler. The specs I know are:
    Weinmann 416 matte annodized 27" X 1 1/4 alloy rims
    Maillard front and rear hubs 36h
    I'm thinking about taking this opportunity to try my hand at rebuilding a wheel. How do I go about determining what size/length spokes and nipples I might need to give this a try? Are there any unique challenges to building a 27" wheel as opposed to a 700c?
    A wheelist
    Reputation: Mike T.'s Avatar
    Read my webpage and the answer to your last question is "no".
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilder's with motivation, information and resources.
    What the what???
    Jul 2009
    Quote Originally Posted by Mike T. View Post
    Excellent. I was planning to use your site as a guide.
    A wheelist
    Quote Originally Posted by Opus51569 View Post
    Use it just as a basic 1st step guide. Get Roger's great e-book (on my links page) and you're good to go.
    What the what???
    Jul 2009
    Any advice on what to use on stuck spokes/nipples? Liquid Wrench? WD-40?
    The Law of Headwinds states: If the ride out seems easy, wait until you turn around...
    A wheelist
    Wire cutters. Save yourself a lot of troubles.
    Thanks for another idea for my site. This is how I get them.
    What the what???
    Jul 2009
    Glad I could help
    Jul 2011
    LOL, yes don't waste your time with the old spokes or nipples.
    A wheelist
    Quote Originally Posted by mikerp View Post
    Me and lots of others have re-used spokes but ones that are damaged, had a long life or have seized nipples just make the job much harder or less reliable that it needs to be.
    What the what???
    Jul 2009
    Well, I'm guessing the spokes are the original ones from 1987 (14ga, zinc coated). They actually look pretty good given their age, but it looks like there's a bit of rust at the nipples on some of them.
    Rather than calculating spoke lengths, can I simply measure then lengths of the existing spokes (the ones I can remove without cutting).
    A wheelist
    Save them for all kinds of home projects like I do.
    Absolutely if you're using the same dimension rim, hub and number of spoke crosses.
    What the what???
    Jul 2009
    Yeah. I'm trying to keep the wheels as original (read: inexpensive) as possible and for my first foray into wheel building, I think a reconstruction might be a good way to start.
    BTW, I tried your fork/bench vise idea for a truing stand. It worked like a charm. I never would have thought to mount the rear wheel on the outside of the fork.
    A wheelist
    There ya go. You can't imagine how many wheels I've tensioned and trued using that setup - or the bike frame & fork.
    Jul 2011
    I don't disagree that they can be reused, for me "old" means they have some degradation (run a spoke through your fingers and they have rust spots from oxidation) hence they are not worth the effort. If I ran into some pristine/NOS spokes I'd work with them.
    A wheelist
    As I've never used any spokes but stainless steel ones since I was a kid, "rust" has never been an issue.
    What the what???
    Jul 2009
    Just to confirm Sheldon's info:
    When I measure the existing spokes, length is determined from the interior of the J-bend to the end of the threads, correct?
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    Yes. It may not be a bad idea to check the existing spokes for correct length. If the spoke end is within 1 mm of being flush with the top of the nipple, the spoke is of the correct length.
    BTW, point the spoke away from you before cutting it with a wire cutter.
    With bicycles in particular, you need to separate between what's merely true and what's important.
    What the what???
    Jul 2009
    I thought I should start with the front wheel. As I was starting to loosen the spokes, I noticed that they thread all the way through the nipple and protrude ever so slightly beyond it.
    Once I got everything disassembled, I measured the spoke and it came out at 305mm. When I purchase the new spokes, should I go with something a bit shorter? 303 maybe?
    grizzly moderator
    Feb 2011
    304 but they may not be easy to find
    What the what???
    Jul 2009
    Quote Originally Posted by dcgriz View Post
    So is the object to have the spoke flush (or just inside) the end of the nipple once the wheel is tensioned? 304 would probably make it flush. 303 would leave it just inside the nipple end.
    Feb 2002
    Stop worrying about it. 303 will be fine. It's just not that critical. 302 would work as well.
  1. Replies: 36
    Last Post: 02-15-2016, 09:41 AM
  2. Replies: 23
    Last Post: 04-04-2013, 01:06 PM
  3. 6' 7" 240 lb Clyde Looking for "Inexpensive" Wheel Setup
    By TallCoolOne in forum Wheels and Tires
    Last Post: 01-23-2010, 10:54 PM
  4. Windsor "The Hour", Moto - "Messenger", Mercier - "Kilo". Differences???
    By midlife_xs's in forum Motobecane - Mercier
    Last Post: 11-04-2007, 08:57 AM
  5. When does "old" = "vintage" or "classic"??
    By Dave Hickey in forum Retro-Classic
    Last Post: 03-06-2006, 10:31 AM
